OC Brewery Arcade meetups
Discussion in 'Southern California' started by WileECoyote, Sep 21, 2016.
  1. Dec 8, 2017 at 9:26 AM
    #5041
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    I hear ya man. I feel like I've had a lot change and yet it all feels the same. Engaged, new house, picked up a second job. 70 work weeks suck!!!!
  2. Dec 8, 2017 at 12:20 PM
    #5042
    rprieto05
    rprieto05 Well-Known Member
    Ralph
    2016 Super White Tacoma TRD 4X4 Off Road
    Nice meeting you guys. Even though I don't remember your names. See you on the trails.
  3. Dec 8, 2017 at 2:25 PM
    #5043
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sounds like your living life my friend.
    It will be with it in the end!
    Stay frosty!
    Papa Taco[QUOTED] likes this.
  4. Dec 11, 2017 at 10:34 AM
    #5044
    jdkarmy
    jdkarmy Well-Known Member
    Anyone have a good place for alignment in South OC? Looking to crank up my coilover a small bit, couple places I called were quoting around $90, was hoping someone around would be closer to $50, going to adjust the coilovers myself
  5. Dec 11, 2017 at 11:00 AM
    #5045
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    If you think you're going to get an alignment for under $90 think again. That's 100% not happening. And in the off chance you find a place that does $50 alignments you're not going to want them to touch your truck.
    If you're just raising your coils you shouldn't need to get a new alignment if you're driving straight.
  6. Dec 11, 2017 at 11:02 AM
    #5046
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
    How high you cranking them? If it’s just a few turns you will be fine no need for alignment
  7. Dec 11, 2017 at 11:23 AM
    #5047
    jdkarmy
    its the fox out of the box height for the 2.5 coilovers right now, the driver side is about .50-.75" lower than the passenger side, was going to crank up the driver side maybe 1" and .25 on the passenger side
  8. Dec 11, 2017 at 11:24 AM
    #5048
    Jimmyboyblue
    Jimmy
    Baja California
    You don’t need an alignment. Just crank them you will be fine
  9. Dec 11, 2017 at 11:24 AM
    #5049
    uhplifted
    Brian
    16 DCLB OR
    If you're already aligned with them on, going up an inch isn't going to throw your alignment off
    Jimmyboyblue likes this.
  10. Dec 11, 2017 at 11:24 AM
    #5050
    jdkarmy
    Must be the going rate then, haven't had to get an alignment done in years. Are there no issues with irregular wear on the tires without getting the alignment done after the adjustment?
  11. Dec 11, 2017 at 11:25 AM
    #5051
    jdkarmy
    Alright that works for me, Thanks for the info
  12. Dec 11, 2017 at 11:25 AM
    #5052
    Jimmyboyblue
    Jimmy
    Baja California
    I’ve adjust mine so many times and have no abnormal wear on my tires .. shit I’ve even swapped out springs and still drives the same
    dtaco06 likes this.
  13. Dec 11, 2017 at 11:26 AM
    #5053
    uhplifted
    Brian
    16 DCLB OR
    Are they already installed? If you're going from OEM to a new suspension then yes, you should get an alignment. If you're already running the Fox's and just cranking an inch up, no, you don't need to get aligned again.
  14. Dec 11, 2017 at 11:31 AM
    #5054
    jdkarmy
    Ya they are already installed and was aligned after the install, drives perfectly straight right now
  15. Dec 11, 2017 at 4:21 PM
    #5055
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Lot of bad info on here.
    Bear alignment in Corona is 65 bucks.. Best alignment your truck will ever get! They don't give a flying fuck what you've done to it...they will align it or you won't pay. Worth the drive IMO. Gotta make an appointment though.
    Any change in ride height whether it be the back or the front will change your alignment. How much...well I couldn't tell you exactly but your tires wearing out prematurely will let you know for sure.
    There's more in my head that I could tell you but you get the idea now right??
  16. Dec 11, 2017 at 4:38 PM
    #5056
    uhplifted
    Brian
    16 DCLB OR
    Thought you said it was more than that. Guess I heard wrong. Lifting up an inch or so doubtfully makes enough of an alignment issue to really warrant a fresh alignment unless you have money to blow. But that's just my opinion.
    Also, everything I said lines up with what you said, besides the cost of alignment. Which I can admit when I'm wrong unlike some people in here
    bigbarlo and Lord Helmet like this.
  17. Dec 11, 2017 at 4:51 PM
    #5057
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I was just correcting the statement that moving it an inch doesn't change much. It may or may not. You don't know until its on the alignment rack. People have the opinion that if it drives straight its good no matter what. Changing the height fucks with caster and camber both of which you cant really see or feel but it's changed. Though a big caster change will make your steering either lighter or heavier depending on which way it changed....so you may feel that I guess. Camber you can see if it changes enough to give you this / \ or \ / ... but an inch in height will most likely not be a noticeable change but it will change I'm just trying to put out the correct info.....your opinion really doesn't count as that.
  18. Dec 11, 2017 at 4:55 PM
    #5058
    uhplifted
    Brian
    16 DCLB OR
    If it drives straight it's good enough for me... but then again I've been driving with a pull to the right for the last 4 or 5 months. One day I'll take it in
    Airdog[QUOTED] likes this.
  19. Dec 11, 2017 at 5:01 PM
    #5059
    uhplifted
    Brian
    16 DCLB OR
    I think I may have knocked it out a little more this weekend. I took a right turn without touching the steering wheel. I'll probably try and make an appointment next week. Won't be driving it much this week
  20. Dec 11, 2017 at 5:55 PM
    #5060
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Shit, one mild trip on dirt can throw off your alignment.
    I would always suggest an alignment after any change in preload. That is, if you like even tire wear :notsure:
    itaro likes this.
