Ocassional clunk/thump when brakes are pressed
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgenyota2014, Dec 2, 2016.
  1. Dec 2, 2016 at 11:04 AM
    1stgenyota2014
    1stgenyota2014 [OP] Well-Known Member
    Garrett
    2004 ext cab Black Tacoma
    Flatbed, OME springs, 5100 billies
    Just like the title there a slight clunking noise when the brakes are pressed going forward and back. Doesn't happen 100% of time. Seems to happen more after sitting/when brakes are cool. I basically rebuilt front end this summer in July, ball joints, tie rods, cvs, bushings, struts. It's been happening since then, I just haven't thought anything of it and now I'm just annoyed, any help will be appreciated.
    opteron likes this.
  2. Dec 2, 2016 at 11:07 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    axle wrap....I'm to lazy to find you link (normally I would). Do a search on it, I just learned to deal with it at this point. You can also try tightening the u-bolts if that doesn't work you try add a leaf kit very inexpensive.
  3. Dec 2, 2016 at 11:49 AM
    1stgenyota2014
    Garrett
    Oh yeah I forgot to mention that I just put some new OME Dakars and rough country shocks about 2 months ago. I thought it was axle wrap too but it wasn't. Any other suggestions?
  4. Dec 2, 2016 at 12:18 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I swapped my front brakes to tundra brakes and noticed a clunk afterward. After a lot of research it appears that the brake pads shift in the caliper on the tundras and make a clack/clunk sound. For some reason it is designed this way from the factory. It only happens when going from braking in reverse to braking in forward or vice versa.
  5. Dec 2, 2016 at 12:23 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Pads shifting or shoes releasing.... worse after sitting a few days?
    Whats the climate like?
  6. Dec 2, 2016 at 2:27 PM
    Maestro
    Maestro Well-Known Member
    The Master
    My axle wrap persisted after I did a full OME w/Dakar install.
    My guess is that you are throwing a ton of money and effort toward the wrong items. Make peace with it and you will find happiness. Otherwise, you may end up replacing EVERYTHING and still end up where you started.
    PROseur likes this.
  7. Dec 2, 2016 at 2:54 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Are you sitting at a dead stop with brakes on and rocking it forward and back? Or you talking slow speeds? Parking lot type speeds? little more info might help narrow it down.
  8. Dec 2, 2016 at 3:11 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Sounds to me like something came loose. I would go back over EVERYTHING that you touched when you did the front and rear work. It could be something as simple as a shock bolt coming loose to front A arm bolt came loose.
  9. Dec 2, 2016 at 6:02 PM
    Tim7902
    Tim7902 Well-Known Member
    Tim
    Maryville, TN
    2001 tacoma doublecab
    Ive just had this same problem happening for the last couple weeks. slowing down while braking causes an intermittent clunk sound. sometimes it happens around 20 miles an hour sometimes right after i come to a complete stop. i havent had much time to look into it just yet but think i will look at the calipers first. it sounds like a metallic cast iron kinda pop and only happens once per stop from the drivers front only. ive read some have had loose lca bolts cause this sound idk.
  10. Dec 2, 2016 at 7:15 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Ya there's something loose somewhere
  11. Dec 2, 2016 at 7:43 PM
    1stgenyota2014
    Garrett
    Thanks for all the info, I'm thinking I'll check the pads if they're shifting.
    Hmm ok I'll have to look more into axle wrap too. I didn't replace everything just cause of the clunk, it was all replaced cause my control arm bushings were seized so couldn't align it. And a torn cv.
    Yeah that's something I have considered, I'll check it. It never really sits for days,1-2 max cause it DD. I'm south Texas so in summer it's was 100 often, now down in 40's occasionally, still does it occasionally.
    Yeah this sounds similar to what's been happening to me except mine hasn't when slowing from 20, it's been from a stop or pulling into driveway type speed.
    It's from a dead stop, not rocking it back and forth but will try it to see if maybe it's the pads shifting. Never does it at parking lot speeds, occasionally pulling into driveway. Most often happens when reversing from driveway, which makes me lean towards it being pads shifting from pulling in forward.
  12. Dec 8, 2016 at 11:56 AM
    tahco_02
    tahco_02 Well-Known Member
    SoCal
    2002 Black TRD PreRunner Access Cab 2WD
    Stage 1 Lift, 16x8 SCS SR8, 285/75-16 Dick Cepek Extreme Country, Ethan's Skid, Driving Lights Mod
  13. Dec 8, 2016 at 12:12 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  14. Dec 8, 2016 at 12:22 PM
    tahco_02
    SoCal
    Traction bars is a cure for axle wrap.
  15. Dec 8, 2016 at 12:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    Could be simple brake related. Slider pins binding, then the caliper 'pops'. Pads moving because of improperly installed retainers, or the little 'return' springs are missing.
    I'd start by pulling out the mounting hardware, being sure it's clean and well lubed, and that all the pad mounting hardware is in place and lubed where it should be lubed.
  16. Dec 8, 2016 at 12:28 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'm noticing the same symptoms on my 02 DC Pre Runner . I'm noticing a slight clunk upon releasing the brake pedal when I'm leaving from a traffic light but its very intermittent
    I'm thinking a brake caliper hanging ??
  17. Dec 8, 2016 at 12:46 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    That's axle wrap
    Exact thing happens to me
    I learned to live with it
  18. Dec 8, 2016 at 12:53 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    check your front wheel bearings.
  19. Dec 8, 2016 at 3:06 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    make sure your drive shaft slip yoke is greased. I grease mine every 4000 miles and it almost eliminates all of the clunk or push feeling when releasing the brake.
    US Marine[QUOTED] likes this.
  20. Dec 8, 2016 at 3:42 PM
    PROseur
    Pussy
    Any how to ?
