Ocassional noise when turning?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Oct 25, 2015.
  1. Oct 25, 2015 at 9:10 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    I have noticed that occasionally when I turn to the left my truck has rubbing noise. It doesn't really happen except at low speeds when I am parking or on a tight turn at low speeds. It is not a metal grinding noise, nor does it impeed my ability to drive or turn, so I think something it rubbing.
    I run stock 265 70 R16's on my truck, and i checked the wheelwell to see if anything caught the tire when the truck was sitting stationary. Also, I got an alignment recently and the shop said that everything was tight and in good working order.
    My front mud flaps are stock and they are kind of floppy so what I am thinking is, that the mud flap on the drivers side is rocking back and forth when I slow down and it hits the tire for a brief moment. This doesnt happen on the passenger side because that mudflap isnt stock and is a harder plastic.
    Any advice, or possible causes?
    Thanks
  2. Oct 25, 2015 at 9:13 PM
    Tjsingle26
    Tom
    PA
    Also, my rack and pinion is brand new as of 2013
  3. Oct 26, 2015 at 10:13 AM
    Tjsingle26
    Tom
    PA
  4. Oct 26, 2015 at 10:21 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Describe the noise. Is it a whiny, small-electric-motor sort of sound?
  5. Oct 26, 2015 at 10:30 AM
    Tjsingle26
    Tom
    PA
    No it's not electric motor sounding, sounds more like something rubbing like the tire on something
  6. Oct 26, 2015 at 10:32 AM
    Tjsingle26
    Tom
    PA
    The odd thing is, and why I think it might be the mudflap, is that it only happens at lower speeds, and when the wheel is turning for a brief second. I think the mudflap is loose and is hitting the tire, I'm not entire sure though.
    It doesn't happen on highways, just really when I'm pulling into a parking spot
  7. Oct 26, 2015 at 10:36 AM
    WheelInTheSky
    G
    Jackson Hole
    Well if it the tire is rubbing the mud flap you will be able to see scratches or at the very least a shiny smooth spot on the flap. Another thing the tire may be rubbing is the pinch weld..
  8. Oct 26, 2015 at 10:40 AM
    Tjsingle26
    Tom
    PA
    I think it's more so that mudflap is rocking back and hitting the tire
