Occasional misfire/cutout
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mcfly6667, Jun 27, 2025.
  1. Jun 27, 2025 at 7:45 AM
    Mcfly6667
    Mcfly6667 [OP] Member
    Ken
    2001 Impulse Red Tacoma 3.4 4wd SR5 TRD
    The combination of lower engine speed (below 1.8k or so) and throttle mostly open, including normal acceleration immediately after up shift. Split second mis-fire a couple few times random intervals until engine speed gets up a bit. I can be a bit less aggressive on the throttle and it happens less. I realize it is not in its power-band but these cut-outs still are not good. If its a long grade I will gear down and keep the RPMs up a bit and its fine. This symptom is usually on-ramps or pulling away form stop lights. 285k on this 3.4 and I still consistently get 20-22 MPG. Starts and runs great otherwise. This seems more like an ignition issue and not really a fuel delivery issue. This engine has that dual/redundant spark system so I guess that means there are only 3 coil packs to deal with...which is my hunch ATM
  2. Jun 27, 2025 at 9:12 AM
    Glamisman
    Glamisman Well-Known Member
    Do you have a scan tool?
    How old are the plug wires?
    What I am hoping for is that you do have a scan tool and that it and the PCM are sophisticated to show live data misfires and/or pending codes. Like you mentioned 3 coils... if the misfires are on a shared coil, swap coils and retest.
  3. Jun 27, 2025 at 10:37 AM
    Mcfly6667
    Ken
    Yes, a simple one
    Possibly original.
    Both good leads (No pun intended)
  4. Jun 27, 2025 at 11:55 AM
    Glamisman
    Without any codes either hard or pending this turns into an exprience game. Do you put a set on new plugs and wires on it "just because" or ?
    Pop your scanner in and see what you can discover of its features, you never know what you will find.
