Occasional no response from throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OldCity, Aug 4, 2022.
  1. Aug 11, 2022 at 4:54 PM
    Queso_Blanco
    Queso_Blanco Formerly known as "Bad_Guac"
    Tyler
    Mesa, AZ
    '23 Super White DCSB TRD OR 4X4
    Accutune stage 4 Adjustable King 2.5's w/resi's All the meso Diamondback HD Method 701's 17x8.5" 285/70R17 Diode dynamics fog/ditch/stealth lightbar Sliders RCI skids OTT tune Total Chaos bed gussets Etc...
    Interesting, I thought I was going sort of crazy. My truck seems to go from one extreme to another with no real pattern.
    I don't think I've had mine 'bog' actually, but the pedal sensitivity definitely has a mind of its own.
    '21 TRD OR DCSB auto
    265/75R16's
    KDMax pro tune at like 2000 miles, currently at roughly 14k miles
    Sometimes my truck hesitates like OP describes and other times the throttle will be be wildly touchy sort of like how the early throttle-by-wire and fuel injected motorcycles felt trying to maintain speed.
    I don't stick to any particular gas station, but its all been 87 octane.
    I had just accepted it as 'normal' figuring the tuning for a pickup would be much less refined compared to other vehicles I've had tuned.
  2. Aug 11, 2022 at 5:18 PM
    OldCity
    OldCity [OP] Well-Known Member
    St Augustine Florida
    2022 Tacoma TRD Offroad DCLB
    Icon Stage 3, 285/70/17 KO2/Fuel Tech 17x9 +1 Offset, Cab mount chop, DiamondBack Tonneau, KDMax Pro+XT,
    When it happens it is definitely “not normal”. It’s like if you were driving a manual and started from a dead stop in 6th gear. Day 2 after not using Costco gas and the truck is fine. Acts like a clogged fuel filter except you bump it in to neutral and throttle response is normal. I’m not the sharpest tool in the shed but I’m pretty good at figuring things out and this one has me stumped. 3200 miles so not concerned because it’s under warranty so we will see.
  3. Aug 28, 2022 at 11:40 AM
    OldCity
    Well after some deductive reasoning I have discovered that the aftermarket Led taillights are the culprit. Sounds crazy but I swapped back to the OEM taillights Friday morning and haven't had a problem since. I had read where some Tundras had experienced issues after installing aftermarket lights. Something to do with voltage/resistance or possibly a bad ground/wiring in the lights themselves that messes with the safety sense system and goes into limp mode even though I never got a light or code. I've reached out to the folks I purchased the lights from to get their take on it. Never would have guessed it. Truck runs great now.
    ktbell444 likes this.
  4. Aug 28, 2022 at 11:43 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    this happens to me during the "learning" process if i change grades of fuel or reset the fuel/air ratios via pulling the EFI fuse. i guess the ECU is still trying to determine proper shift points and sometimes it hiccups. goes away after a while but it takes like 3-4 full tanks of gas for it to learn. takes a longggg time.
  5. Aug 28, 2022 at 12:52 PM
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    If I pump the gas rapidly at a stop, it will hesitate and basically just idle for about 2-3 painfully long seconds (it's happened at awkward stop signs), but I've never gone from 0 throttle stopped to 1/4 quarter in one fluid press and it just doesn't respond. I have the 4 cylinder so I get a boosted throttle response whereas the V6 3rd gens get a sluggish throttle response. I run 85 octane by the way. I don't buy any of the octane arguments on this forum. It's very possible that the truck is still trying to adapt to your driving habits and it's getting confused. After I put 3000 miles on my Tacoma, it dawned on me how much better it drove than when I first bought.
    Using a different gas and returning to OEM lights improving is perplexing.
  6. Aug 28, 2022 at 12:53 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Interesting. I never would have put that cause and effect together. Whose aftermarket tail lights were they?
  7. Aug 28, 2022 at 1:00 PM
    OldCity
    It’s got nothing to do with the fuel or octane. The problem wasn’t just some minor hesitation it was significant and dangerous. I can’t explain the taillights being the problem but I’m 99.9% sure that they are.
  8. Aug 28, 2022 at 1:01 PM
    OldCity
    Alpha Rex
  9. Aug 28, 2022 at 3:04 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    I've taken mine in for this issue and the techs say its normal of course.. i have an old fly by wire car and the response is far more linear than the taco, if i move the pedal a little i hear and see a change. in the taco, if i apply the same movement there may or may not be change in acceleration or rpms; leading to a deeper press to illicit a response. the dealership says it is noted in the event logs (double tap) and thus says its driver related (nevermind that i'm double pressing after 3 seconds of nothing). in a way i feel like i'm driving a horse but even a horse is more responsive to little nudges
