occasional steering wheel shake while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Aug 22, 2014.
  1. Aug 22, 2014 at 2:29 PM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I have a 2013 Tacoma 4x4 v6, I have noticed occasional steering wheel shake while braking at approximately 70mph,it doesn't do it all the time, just sometimes. I only have like 30,000 miles on it,if it were warped rotors it would do it all the time, right? Besides at 30,000 miles my rotors shouldn't warp anyway, right? What could it be? Thanx!
  2. Aug 22, 2014 at 4:11 PM
    tacomalimited
    Northern NJ
    Guess I'm the only one with this problem.
  3. Aug 22, 2014 at 4:31 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    I would pull the front wheels off and spray your breaks down with brake clean. If you do not have a shimmy when not breaking it should not be your tires out of balance but you could rotate the rear tires to the front to check that. Your rotors being warped depends on your driving style plus driving through a puddle with hot brakes could do it. Brakes and rotors are pretty cheap and simple to swap out. 30K could be just about time depending on your habits. If is happens on the same road it could be the surface as well.
  4. Aug 22, 2014 at 4:37 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    ive had one drum turned at 5k bought the truck with 4,268 due to demo model. Just had it back to toyota due to front rotors. It was bad enough for the tech to feel it this time but had it in before and the said they didnt feel anything. Im at 26k now and i still feel some but its very little in the seat which is rear brakes. When take it to my uncles shop to install my lift and wheels ill throw the drums on the lathe and do it myself. I only have 10k left of warranty so im not worried. If anything is said ill just have him wright me up a ticket as i paid for the service.
    steering wheel its front seat is rear while you hit the brakes its something slightly warped. should shake or pulse unless something is wore out or warped in the brakes.
    If its under warranty take it in. if not its usually like 20 to 25 a rotor to have them turned.
  5. Aug 22, 2014 at 4:45 PM
    JJ Customs
    Jay
    NV
    If you decide to have your rotors turned be sure to do both not just one! This goes for replacing them also. Always do brakes as a set. I doubt the issue is in your drums so I would focus on the front. In my opinion just throw a set of pads and new rotors in the front. Do it yourself and it should cost you less than $100.00 for it all and at max an hour of your time.
  6. Aug 22, 2014 at 4:48 PM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    I've had wheel shake before and it turned out to be a certain stretch of freeway that I travel occasionally. I thought something was wrong at first. It took me a while to realize it only happened on that certain section of road (about five miles worth). The road doesn't appear any different either.
    I'm not saying this is your issue - just that it's not always the vehicle's fault.
  7. Aug 22, 2014 at 4:50 PM
    tacomalimited
    Northern NJ
    I don't know, before I had this,I had a Chevy Colorado,it had 75,000 miles on it, and I never did anything to if as far as brakes. I can't believe I may need some type of brake work done on my Toyota at 30,000 miles! I was planning on keeping this truck for a loooooong time, now I'm not so sure.
  8. Aug 22, 2014 at 4:55 PM
    tacomalimited
    Northern NJ
    I was hoping that was the case,but it happens on a few different roads. I don't know why I can go some days without feeling it, then feel it the next day,its so sporadic, it's weird! If it was warped rotors, wouldn't it happen consistently?
  9. Aug 22, 2014 at 4:55 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    As what was said drums are felt in the rear, steering wheel or whole truck is normally the fronts. I was stating i had a issue with mine at 5k and toyota did take care of both issues when they felt it. Anything in the brakes should be replaced in pairs. You wouldn't believe how many people come in wanting on side of pads or one pad.
  10. Aug 22, 2014 at 4:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ If you're hitting the brakes at 70 mph frequently, IMO you're lucky they've lasted this long.
  11. Aug 22, 2014 at 5:00 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    I felt mine more towards mid morning to evening. Once the brakes were hot. toyota thought i was nuts but Ive had warped rotors before that did the same thing.
    Only thing you can do is start checking everything or have it looked at. You can get a dial gauge and turn your rotor to see if you have any run-out. If you have a shop do it on the truck vs taking them off you get a better cut. If done right you will have 0 run out due to the machine cutting them while on the truck to that set up. if take it off then it can give you slight run out but not alot due the machine. Youtube it.
  12. Aug 22, 2014 at 5:03 PM
    tacomalimited
    Northern NJ
    I don't have a problem replacing both pads or rotors at the same time,my problem is ,I can't believe I need brake work at 30,000 miles!!!! I hope I don't need rotors yet!
  13. Aug 22, 2014 at 5:06 PM
    tacomalimited
    Northern NJ
    I'm not hitting them frequently, just when I need to slow down.
  14. Aug 22, 2014 at 5:08 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Thats what i thought along with many others that have swapped out many of sets due to warping. Ive seen a few threads talking about what the best rotors are due to issues with warping or wanting better braking.
  15. Aug 22, 2014 at 5:10 PM
    tacomalimited
    Northern NJ
    Guess I'll bring it back to the dealer and see what they say, they'll probably say it's normal, until my warranty expires in 6000 miles.
  16. Aug 22, 2014 at 5:39 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    I had a 2008 Ranger, front disc/rear drums. Had the same shake at 25K, dealer told me it was a "normal wear, not covered by warranty issue", had the discs turned that fixed it till 40K, shake back, replaced rotars and pads with auto parts store stuff, no more problems, traded for Taco at 60K
