Occasional steering wheel vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoreyF, Oct 1, 2024.
  1. Oct 1, 2024 at 12:44 PM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access Cab V6 Automatic
    On rare occasions, my steering wheel will vibrate after getting up to and above about 40 mph. It's the same symptom you would get if your tires were out of balance. It is minor though and it goes away in about 30 seconds. It only happens on occasion, and it drives fine otherwise. It rides nice and smooth, and I also don't have any wheel pull as if it might need an alignment. That is fine too. Tire pressures are good. Brakes appear to be working normally. (all four brake shoes and pads were recently replaced, and rotors resurfaced). What could be causing this to happen just here and there?
  2. Oct 1, 2024 at 7:23 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    If it only happens rarely and you can't easily replicate it, maybe it could be something like steering rack bushings being worn out or the steering rack bolts being loose? Just thinking out loud. Not sure but good luck finding the source.
  3. Oct 2, 2024 at 7:44 AM
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    Tires flat spotting? Does it happen when the truck sits for a week or so?
  4. Oct 7, 2024 at 10:28 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    No, I drive my truck daily. The vibration actually happened this morning but quickly went away. It does this whatever the outside temperature may be too. It's rare this happens though. I plan on having the tires checked out/ balanced soon.
    Update: Apparently one tire was just slightly out of balance, so the vibration was not present constantly. Toyota dealer fixed the issue, and it is fine now.
    Well, I thought it was resolved but it is not. It vibrated again this morning once I reach about 50-60 + mph. I had all tires balanced as mentioned but not the alignment because it seems fine. I have not hit any pot holes. Here is what I have thought about for suggestions from anyone:
    • Should I check alignment anyway?
    • Out of round tire.
    • There are no clicking sounds to indicate a CV axle issue.
    • Wheel bearings. Does my truck have them?
    • Tires look great with plenty of tread.
    • Tire pressures are fine.
    • No vibration when pressing the brakes.
    • Bent wheel.
    • Mileage will be at 98,000 soon.
