Occasional Towing - Suspension Upgrades
Discussion in 'Towing' started by webs93, Jan 30, 2025.
  1. Jan 30, 2025 at 6:28 PM
    webs93
    webs93 [OP] New Member
    2014 SR5 4.0L
    Stock
    Hello,
    I've been digging around on here for answers to my questions, but thought I would just ask and see what people say for my specific situation. I drive a 2nd gen SR5 4.0L and am looking at buying a 2 spot sled trailer. Estimated loaded weight is 3,000 lbs, plus gear in the truck. I would like to upgrade my back end so I'm level and am not riding on my bump stops. I'm guessing I would be hauling it a dozen times a year.
    The options I'm looking at:
    1) Firestone ride rite airbags with stock leafs
    2) Firestone ride rite airbags with upgraded leafs
    I know there are other options like RAS, sumo springs, etc. But based on what I've read I would likely do one of the options listed above. Is upgrading leafs with air bags overkill? Are airbags enough?
    thanks for your time
  2. Jan 30, 2025 at 7:28 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Assuming you have the tow package you shouldn’t have to do anything to your truck to tow 3000lbs. It certainly wouldn’t hurt to install airbags or upgraded leafs but I don’t see the need or real benefit. I have a second gen Sport TRD 4x4 with tow package. My only upgrade is heavy duty rear leafs (which I didn’t really need). I tow my boat/trailer which is 3500 lbs with no problems or complaints. In your case other than a brake controller (assuming your trailer has brakes) I wouldn’t do anything. Wait til you get the trailer and tow it, then decide if you want or need any tow mods.
  3. Jan 30, 2025 at 7:39 PM
    webs93
    2014 SR5 4.0L
    Stock
    I appreciate the insight. Yes, I have tow package and brakes on the trailer. A controller is on order.
    Sprig likes this.
  4. May 9, 2025 at 3:40 PM
    soggyBottom
    soggyBottom Well-Known Member
    Trailer brake requirements are based on the gross weight printed on the trailer.
    Air bags are great for towing but suck for everything else. They reduce your up travel. Even light off roading is much harsher.
    Add a leafs are nice, cheap, and easy to install, but they will raise the suspension.
    I've heard great things about sumo springs but I have no first hand experience with them
    Amazon has a nice weight distribution hitch. It's not needed for 3000lbs but it will reduce the sag on the rear. No drilling, but 2 of the bolts need something like 260ft lbs. Currently $350 -- REESE 49911 Integrated Sway Control Weight Distribution Kit, 6,000 lbs. Capacity, Shank Include
    https://www.amazon.com/dp/B07YLCKJLJ
