Occassionally Stuck in Park (AT) - Will Not Shift Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travel John, Sep 13, 2017.
  1. Sep 13, 2017 at 2:52 PM
    Travel John
    Travel John [OP] Active Member
    Puget Sound
    07 DCSB 4x4 Off Road
    OME 886 w/ Dakar & Nitros, ARB Bull Bar, All Pro Sliders w/ Kick-Outs, "grey wire" mod, ABS Kill Switch, CB Install, Rino Rack Awning, James Baroud RTT
    Hi There -
    My truck (V6 AT) is occasionally stuck in park and will not shift to reverse etc. This occurs probably 60% of the time I currently start my truck. When it occurs, I usually have to cycle through depressing the brake peddle several times and then it shifts. I have read several threads about sensors and trailer brake light wiring impacting the shift lock, but I can't pin point the issue with my truck. Anyone have any insight or a thread to direct me to that I have not yet found.
    Thanks!
    J
  2. Sep 13, 2017 at 2:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have you checked the brake switch. That is what activates the unlocking of the shift lock solenoid.
  3. Dec 15, 2017 at 8:59 AM
    Travel John
    Puget Sound
    Just realized I never closed this issue of for others to reference...
    @Jimmyh was correct (Thank You) - The Brake Switch was faulty. Its primarily called the Brake Light Sensor but controls both the solenoid for shifting our of park and brake lights.
    J
    Capt. Obvious likes this.
  4. Dec 15, 2017 at 1:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup: Thanks for the update!
