Ocd about alignment. Have a question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ievko82, May 3, 2017.
  1. May 4, 2017 at 12:28 PM
    ievko82
    ievko82 [OP] Well-Known Member
    WV
    17 sport DCSB quicksand
    I wasn't getting a pull before. Hope I don't get one now haha.
  2. May 4, 2017 at 12:29 PM
    su.b.rat
    su.b.rat broken truck
    ha! wrong thread. :hattip:
  3. May 4, 2017 at 12:30 PM
    ievko82
    WV
    Haha I figured. I think I saw the one where the guy was pulling to the right.
    su.b.rat[QUOTED] likes this.
  4. May 4, 2017 at 12:54 PM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Positive or negative camber ??
  5. May 4, 2017 at 1:30 PM
    ievko82
    WV
    It's was positive camber.
  6. May 5, 2017 at 4:04 PM
    ievko82
    WV
    Ok I shouldn't have said anything. I've noticed I have a very very slight pull to the right now. I'm figuring it's alignment related since it didnt do it with the first alignment. Can anyone see anything that may cause that with the specs I posted on the first page?
  7. May 5, 2017 at 4:19 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Your specs look good. Caster is a little low, ideally 1.5* on stock UCA's is achievable. What people dont understand is when you add UCA's with either 2* additional caster or SPC's that can do 4* more caster you are losing firewall clearance. Ideally you would want more LCA adjustment to get the caster you want that way firewall clearance does not become an issue. So going with new UCA's can actually make you rub a lot more at the firewall than with stock arms.
    Usually if you have a good toe you will track straight. The caster/camber really doesnt affect tracking straight like toe does. Most roads have a slight angle to the right to shed water. Is this maybe the pull your feeling?
  8. May 5, 2017 at 4:32 PM
    ievko82
    WV
    I'm thinking that is the pull. Between the lower caster, and a bit wider tires with a -10 offset wheel it might just be a bit more exaggerated when the road dips to one side. I also don't think my steering wheel isn't 100% straight, but I'll be going back after I take my cam bolts out to anti seize them. Thank you for the reply
    JayRolla[QUOTED] likes this.
