OCD about transmission wear and shifting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pdaddy, Feb 4, 2020.
Are you OCD about gear shifting and wear?
  1. Yes, me too!
    5 vote(s)
    15.6%
  2. No, you’re weird
    27 vote(s)
    84.4%
  1. Feb 4, 2020 at 8:10 PM
    pdaddy
    pdaddy [OP] WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Anyone else conscious about limiting gear shifts while driving to prevent wear?
    Examples I do: In stop and go traffic, I put it in 1st gear to prevent upshifting. When climbing hills, I ease off the gas and lose speed so it doesn’t downshift. I try to park in a way so I don’t have to reverse out of it when I leave. Overall, I just try to avoid changing gears once I’m at speed. I used to do the same thing in my old 5 speed 1st gen. Maybe I’m just weird and maybe it doesn’t help longevity of the transmission at all idk:notsure:
  2. Feb 4, 2020 at 8:11 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    MTs are fairly bullet proof. They take plenty of abuse. Don't worry about it. If you are talking about doing that to an AT, seek help.
  3. Feb 4, 2020 at 8:14 PM
    Running Board Man
    Running Board Man Well-Known Member
    auto... i do the same thing
    pdaddy[OP] likes this.
  4. Feb 4, 2020 at 8:14 PM
    pdaddy
    Preston
    Central AL
    Yea my truck is an AT:(
    Running Board Man likes this.
  5. Feb 4, 2020 at 8:46 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Stop n go ill drop to first just so i can use engine braking so i dont have to move my foot cus im lazy
    I will limit on power downshifts to 4th from 5th at cruising speed (60+mph) if i can... that is if a hill is coming up that i know will cause at a minimum of an unlocking of the torque converter in 5th if not a full downshift to 4th, I will pop it into 4th on the flat before the hill so the trans isnt shifting under as much load and can get into lockup before the hill keeping trans temps down. But realistically.... throw it in D and run her and dont worry so long as you deal with fluid changes on the proper regular.
    TnShooter and steveo27 like this.
  6. Feb 4, 2020 at 10:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If I find it shifting too often, I will drop down a gear. (This includes converter Lock/Unlocking)
    Towing I usually run 4th gear.
    Other than that I pretty much just run 5th.
    I don’t usually engine/trans brake.
    I don’t tow that much weight to need to.
    I figure brakes are cheaper to fix and repair?
  7. Feb 5, 2020 at 4:48 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Nope. Just drive it.
  8. Feb 5, 2020 at 4:50 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Just change the transmission oil at regular intervals and you should be good to go. Lots of good threads on that here at TW. No need to fuss with the gears otherwise.
  9. Feb 5, 2020 at 7:37 AM
    nd4spdbh
    SoCal
    Yup same sentiment here. I will say I do use engine braking in 4th and 3rd (and sometimes 2nd if needed) on longer grades if im loaded down and need to hold speed for a good chunk of time. Brakes are meant to stop you, gears are meant to maintain speed.
    TnShooter[QUOTED] likes this.
  10. Feb 5, 2020 at 7:46 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Just drive it. The transmissions in modern cars are designed for good longevity when you just get in, put it in D, and go. They expect people not to know any different these days. If you're towing that's different, I wouldn't want it to go into OD unless I'm on flat ground without a head wind.
  11. Feb 5, 2020 at 7:53 AM
    Bishop84
    Bishop84 Well-Known Member
    1st is actually harder on the trans, it uses engine braking rather than the overun.
    D for drive. Thats it. Park using the parking brake is the best advise.
    Toyota has really robust truck transmissions, I have changed 5 in my career of 16 years.
    TnShooter and tacom08 like this.
  12. Feb 5, 2020 at 9:56 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Transmission Temp.jpg Some of the misconception is the transmission fluid isn't used for lubrication solely, its used more for hydraulics in the transmission. The transmission fluid will be more susceptible to heat if towing a trailer ect. Equally important will be to monitor the temperature to the transmission oil to get the longevity as stated "lifetime Fluid". My first Tacoma was a first gen with 375000 Km when sold and is still running thanks to regular maintenance on all fluids and oils ect.
    I think the fact its not uncommon to see Tacomas in great condition with high mileage speaks to the adage ....An ounce of prevention is worth a pound of cure. A little precaution before a crisis occurs is preferable to a lot of fixing up afterwards
    Great to hear all the comments...go team TW!
    jkuniverse and nd4spdbh like this.
  13. Feb 5, 2020 at 10:00 AM
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    I only downshift going down big hills.
  14. Feb 5, 2020 at 10:05 AM
    alpentolic
    alpentolic Member
    2000 Tacoma SR5
    I downshift on hills as well. Never worry about my trans much at all (293K on my 2000), but i do take extra time in the mornings to let it shift up into second on my way out of the driveway.
  15. Feb 5, 2020 at 10:18 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Just drive it.
    I'd be curious if there's any case study's out there to show if the difference in driving behavior actually affects the longevity of the transmission. There would be a ton of inconsistencies to even have a legit study though.
  16. Feb 5, 2020 at 10:37 AM
    Running Board Man
    On cold mornings i put it in drive set the ebrake and give it gas to warm up the fluid till its to about 120 on my scanguage than it shifts normally
  17. Feb 5, 2020 at 10:55 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    just drive, especially for normal driving. I only become conscious of it when under extreme conditions like towing, plowing, mountain climbs etc. Stop and go, youre not putting much pressure on the system unless you floor it until your next stop over and over again.
    Jaypown likes this.
  18. Feb 5, 2020 at 10:59 AM
    81shark
    81shark Well-Known Member
    defiantly consider seeking professional help
    goforbroke123 likes this.
  19. Feb 5, 2020 at 11:01 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I've never heard of this in my life... and i'd never try it. but if it makes you happy!
  20. Feb 5, 2020 at 11:02 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sometimes I may drop it down in 4th if I'm driving in town. But 95% of the time I just leave it in D
