OCT/NOV annual New England+ Fluid Film Meet - ENCORE
Discussion in 'Detailing' started by surfandturf, Aug 2, 2018.
  1. Sep 1, 2018 at 11:40 AM
    #101
    VADER
    VADER Well-Known Member
    Connecticut
    2018 Tacoma TRD OR DCSB
    Awesome, thanks!!
  2. Sep 1, 2018 at 7:09 PM
    #102
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    I'm doubtful at this point, heading to Maine for vacation Monday and will be getting back Sunday. Already have a lot of driving ahead of me without adding a drive to CT :pout: I'll just have to PM @surfandturf to set up a time when I get free time.
    DrFunker[QUOTED] likes this.
  3. Sep 2, 2018 at 2:31 AM
    #103
    DrFunker
    DrFunker Well-Known Member
    :thumbsup:
  4. Sep 2, 2018 at 11:31 PM
    #104
    Bamareb
    Bamareb Member
    Andrew
    Surf and turf
    I am very interested. 9/23 would work.. I have a 2016 that’s never been done. I was considering Ziebart until someone directed me to this thread. Can you please educate me? Compare your work to a Ziebart job? I’m in North Jersey and really don’t have the appetite to drive 2.5 hours to Ziebart and leave the truck for 3 days. I want it done right for sure.....but saving some $ and keeping my Taco sounds damn good.
  5. Sep 3, 2018 at 5:09 AM
    #105
    surfandturf
    surfandturf [OP] Well-Known Member
    CT
    2014 TRD DCLB
    Ziebart has several rust solutions so it depends on the product. However, most ziebarts put down a permanent under coating. I'm sure it works great on a new vehicle and will stay great as long as it doesn't crack. Any of the rubberized coatings are going to be a problem when they crack and allow corrosion to start under the rust barrier. I have no idea what that costs
    I do know that fluid film should be applied annually and it never really dries. It stays wet and uses a lanolin based wax to create a chemical barrier between the truck and elements that will create rust.
    Ziebart and FF are 2 different approaches to rust prevention. I spray everything under thr truck causing no harm to electrical connections. Ziebart probably just focuses on the frames and chassis
    Hope that helps.
  6. Sep 3, 2018 at 7:36 AM
    #106
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    @surfandturf, is your little guy going to be around on Sunday? Trying to figure out if I should, or could, bring my son with me so he can play with yours.
  7. Sep 3, 2018 at 8:19 AM
    #107
    surfandturf
    CT
    2014 TRD DCLB
    Not sure yet, will check with my wife
    Cativelense[QUOTED] likes this.
  8. Sep 3, 2018 at 8:21 AM
    #108
    surfandturf
    CT
    2014 TRD DCLB
  9. Sep 3, 2018 at 8:21 AM
    #109
    Cativelense
    Nuno
    CT
    Sounds good. Just in case, mine is 4 and likes to run around and is pretty much up for playing with anything. He's been in daycare since he was 6 months old, so he's pretty good about playing with others. Figured I'd throw that out there just in case.
  10. Sep 3, 2018 at 8:23 AM
    #110
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    I might be in, coming from Westchester county
    Cativelense likes this.
  11. Sep 3, 2018 at 8:37 AM
    #111
    Cativelense
    Nuno
    CT
    A few of us are likely meeting up at McDonald's off of exit 25 on 84. You're more than welcome to meet up with us. Still have to figure out time.
  12. Sep 3, 2018 at 9:31 AM
    #112
    crazychris4124
    wasn't that exit closed last time since they took out the bridge?? McDonald's address is 530 Reidville Dr, Waterbury, CT 06705??
  13. Sep 3, 2018 at 10:24 AM
    #113
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
  14. Sep 3, 2018 at 12:03 PM
    #114
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    @tacobell007 drew are you still going to this? Looking to see you and others want to meet up and drive down
    tacobell007 likes this.
  15. Sep 3, 2018 at 12:44 PM
    #115
    Cativelense
    Nuno
    CT
    No, they reopened it recently. The work is done on that side of 84.
  16. Sep 3, 2018 at 1:27 PM
    #116
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I'm planning on it. I think @Boston10Taco is planning on going as well
  17. Sep 3, 2018 at 1:28 PM
    #117
    crazychris4124
    So how does this work and we going for beers after??
    Dgibson529 likes this.
  18. Sep 3, 2018 at 1:31 PM
    #118
    DrFunker
    Beers? o_O
    :cheers:
    Boston10Taco and Dgibson529 like this.
  19. Sep 3, 2018 at 2:30 PM
    #119
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    What time you guys making the trek?
    tacobell007[QUOTED] likes this.
  20. Sep 3, 2018 at 3:47 PM
    #120
    surfandturf
    CT
    2014 TRD DCLB
    Feel free to bring beers. There are some breweries in the area too
