octane levels
Discussion in 'X-Runners' started by bram, Apr 1, 2009.
  1. Apr 1, 2009 at 9:22 AM
    bram
    bram [OP] Well-Known Member
    Bram
    belgium
    08 x-runner
    bedlid. custom made intake ... dt shorties and a flowtech warlock mufler lpi install and some music
    hey i live in belgium and have imported an x.
    out here we run on 95 or 98 octane fuel .
    what are the numbers in the us?:confused:
    (i'm thinking about changing compression ratio):proposetoast:
  2. Apr 1, 2009 at 9:28 AM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    We have 87, 89, and 91.
  3. Apr 1, 2009 at 10:03 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Belgium...cool any chance you could post any pics of your x-runner
  4. Apr 1, 2009 at 10:11 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    98.....wish we could get that here in the U.S.A......is that jet fuel?
  5. Apr 1, 2009 at 11:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    And sometimes 93
  6. Apr 1, 2009 at 3:22 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    87 89 91 :d
  7. Apr 1, 2009 at 9:36 PM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Same up here in Nor-Cal
  8. Apr 1, 2009 at 10:00 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Here's a little info on octane rating systems:
    Measurement methods
    The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
    There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
    In most countries (including all of Europe and Australia) the "headline" octane rating, shown on the pump, is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, the octane rating shown in the United States is 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, is 91–92 in Europe. However most European pumps deliver 95 (RON) as "unleaded", equivalent to 90–91 US (R+M)/2, and some even deliver 98 (RON), 100 (RON), or 102 (RON).[2]
  9. Apr 1, 2009 at 10:03 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Yep, we've got 93 all over the place in Texas.
  10. Apr 30, 2009 at 7:31 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    In charlotte there are a couple of places you can get 100 put the nozzel is to big to fit so you have to put it into a can then your car
  11. Apr 30, 2009 at 7:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    AVGAS (for piston aircraft engines) rates between ~100 and 130 octane. There are some density standards due to altitude...so the 100 octane rating is more or less equivalent to the octane rating on the gas pumps for cars.
    JET A/JET A-1/JET B/JP4/5/8- are jet fuels. They do not have an octane rating. Jet engines compress air without fuel, then introduce fuel into the compressed air and ignites it- No need for octane specifically, as there is no need for the fuel to withstand compressibility.
    All that nerdy mumbo jumbo being said- 100, 103, 108 never really impressed my bike...I'd be interested to see a dyno on it....
  12. Apr 30, 2009 at 8:18 AM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    Colorado: 85, 87 and 91.
  13. Apr 30, 2009 at 8:23 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    In virginia we have 87, 89 and 93
  14. Jun 12, 2009 at 6:31 AM
    bram
    Bram
    belgium
    08 x-runner
    thanks, now i know howmuch the engine can take
  15. Jun 12, 2009 at 6:33 AM
    bram
    Bram
    belgium
    08 x-runner
    will try to post some pics (but its just a standard black x) ON THE OUTSIDE
  16. Jun 22, 2009 at 2:08 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    87;89;91 here... For some reason my truck gets best mileage running the 87.
