octane rating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chicken lips, Dec 12, 2008.
  1. Dec 12, 2008 at 4:32 PM
    chicken lips
    chicken lips [OP] Well-Known Member
    Jose Garcia
    riverside
    07 tacoma
    bone stock for now
    my owners manual was thrown out before i got my truck, so i been wondering what octane rating does toyota recommend for a 07 v6 4.0 truck?
  2. Dec 12, 2008 at 4:33 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Regular 87 octane. It'll give you an 8:1 compression ratio.
    If you want you can use Premium and that'll give you a 10:1 compression.
    So long as you're consistent with what you put in, it'll be fine.
    Personally I run Premium.
  3. Dec 12, 2008 at 4:34 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
  4. Dec 12, 2008 at 4:34 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    premium for maximum performance... but alot of people are running 87. the tick is less noticeable with premium
  5. Dec 12, 2008 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The compression ratio doesnt change when useing a different grade of fuel.
  6. Dec 12, 2008 at 5:28 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I just regurgitated what I read on these forums a couple times from various threads. If I've been mislead, I'll shut the hell up and stop misleading other people.
  7. Dec 12, 2008 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No need to "shut the hell up", Im just correcting you. :)
  8. Dec 12, 2008 at 5:39 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    No worries. But if I don't have anything productive to say, I might as well keep quiet.
    Don't suppose you'd know what they were talking about the changing compression rations then hey?
  9. Dec 12, 2008 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent heard of an engine that has a variable compression ratio in a production gasoline engine. SAAB intoduced one years ago, but I havent heard anything about it since. A variable compression ratio engine is kinda like the "Golden Egg". It can be done, but its very costly and machanically complex.
  10. Dec 12, 2008 at 6:02 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    man, regular sure is A lot cheaper... hard for me to fill it super when regular is like $1.44 here in NJ. :)
  11. Dec 12, 2008 at 6:28 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Dude! Premium used to be over $4/gallon; $1.77 ain't bad at all. I didn't think we'd see under $2/gallon again...
  12. Dec 12, 2008 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2, and being as 91 is $0.20 a gallon more than 87, I found its cheaper to run the 91 as I get better mpg too.
  13. Dec 12, 2008 at 6:37 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i know... i know.. but the gas got so cheap... it just looks so good!!
  14. Dec 12, 2008 at 7:22 PM
    AK27
    AK27 Well-Known Member
    i have a question for you guys, i run regular fuel for a while and i commute a lot each day. i have noticed that with reg gas my truck runs a hell of a lot rougher (idles rough, not as good gas mileage, more engine noise, etc). however if i run premium, the rough idle disappears, i get a heck of a lot better gas mileage and then engine noises are less noticeable. could i potentially have an engine issue or just keep with the premium?
  15. Dec 12, 2008 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just run the preimium. My owners manual actually says "for best performance use priemium fuel".
  16. Dec 12, 2008 at 7:25 PM
    AK27
    thanks chris, i figured so. the difference i get in mileage actually makes it cheaper to buy prem then it does to have to fill up more often with reg.
  17. Dec 12, 2008 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    thast precisely what I have found. :)
