Octane?
Discussion in '4 Cylinder' started by dannybten23, Dec 18, 2013.
  1. Dec 18, 2013 at 12:54 AM
    dannybten23
    dannybten23 [OP] Active Member
    I have a 1998 access cab 4 banger with intake and exhaust. Does higher octane give me better performance or better MPG or a cleaner engine over the life of the truck? Is there any reason to use higher octane other than avoiding knocking?
  2. Dec 18, 2013 at 1:25 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    90+ or nothing! Better MPG & performance. It's not so much the octane as the absence of ethanol:puke:
  3. Dec 18, 2013 at 1:40 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ive always run 91+ anyhow
  4. Dec 18, 2013 at 2:39 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Point has been argued many times everyone has an opinion mine is 87 is just fine.
  5. Dec 18, 2013 at 3:31 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    Octane [technically Octane Rating] is a rating of a fuel's ability to withstand heat & pressure without detonating (pinging) As compression ratios rise, greater octane ratings are required to avoid pinging or knocking. Unless the engine has a higher compression ratio to take advantage of the higher octane fuel, there's NO benefit to be derived from using the more expensive fuel. If an engine will run on 87 octane without pinging there's NO advantage to be gained by using 91 octane fuel. Convincing yourself that the more expensive fuel is better / makes more power / delivers increased mileage or makes you look sexier - is like saying the emperor's clothes are beautiful when he's naked.
    Think of octane ratings like a ladder; if the roof is 10 feet tall you need a ladder that's about 12 feet long, a 30 foot ladder will work but it's more expensive, heavier and doesn't work any better than the 12' ladder. You can't take advantage of the extra length extending beyond the roof.
    So, if you just want to spend more money the gas companies are happy to sell you expensive gasoline.
  6. Dec 18, 2013 at 3:57 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Most of my driving is doing 35-45mph granny-style; if I'm running 87 or 91, I don't notice the difference in performance
    However, every once in a while I'll take the freeway; and I'll mat it the entire on-ramp. I notice a considerable difference in acceleration / performance consistency if I have 87 or 91 then
    That's not why I bought a Tacoma, though; so, I'm not terribly concerned over that
    Also, if I was to say I don't get any extra gas mileage with 91 over 87 WHEN EVERY SINGLE TIME I RUN IT I CLOCK EXTRA GAS MILEAGE that would be like me looking at an emperor naked... ... errr... what?
  7. Dec 18, 2013 at 4:11 AM
    Petrol
    Central Va.
    Tacoma
    You voted for Obama, twice , didn't you?
  8. Dec 18, 2013 at 4:14 AM
    flatblack
    CDA
    nah, dude... i just accelerate a bit smoother and get a couple more miles on my tank with a higher octane... ...
    Edit: I didn't notice it till now; but, this is a 4 cyl thread... I have a 3.4L
    maybe your experiences will be different: I'm not familiar with the 2.7L
    sorry I crashed the party
  9. Dec 18, 2013 at 5:29 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I noticed my truck doesn't rattle on really cold mornings if I put mid grade or premium in it.
  10. Dec 18, 2013 at 11:51 AM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    I with out a shadow of doubt can say my 4cyl accelerates better getting on the interstate with v power in the tank than it does with joe blow unleaded. If someone without me knowing filled my truck with unleaded and had me do my daily commute I could tell you there was a difference.
  11. Dec 19, 2013 at 9:18 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I get good gas mileage, no pinging and plenty of power with 87. Higher octane in the 2.7 is not necessary. It is designed for 87.
  12. Dec 20, 2013 at 10:53 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    If your vehicle was designed for 87 Octane, you will get no benefit from running a higher octane.
