Odd bald spot on tire
Discussion in 'General Automotive' started by Schwinn, Jul 19, 2012.
  1. Jul 19, 2012 at 8:07 PM
    Schwinn
    Schwinn [OP] Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    My wife's van had been pulling almost since day one. I fought with the local dealership to no avail. The I noticed we had a tire with a round spot that was bald. Didn't go all the way around, or across. Took it to a different dealership, and they said a broken belt. Was going to fight paying for it, but all four tires needed to be changed, so decided it wasn't worth fighting and getting all worked up about.
    Then the other day I was walking by, and I noticed it is starting again. The only thing I can think of is something is bent. It's on the rear. Any ideas?
  2. Jul 20, 2012 at 11:38 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Bent axle or rim? Follow while your wife is driving the van and watch it.
  3. Jul 20, 2012 at 11:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Assuming you rotated the tires, I would guess the problem lies on the wheel/tire itself. If it were part of the suspension, it would correct itself when you rotated the tires.
  4. Jul 20, 2012 at 12:40 PM
    Schwinn
    Jamie
    Georgina, ON
    I hadn't rotated the tires on the van yet when I found it. On the previous set, we had done a tonne of driving without rotating the tires (kept forgetting, because on the car I had, I just switched the wheels with the seasons, and since they were directional, I'd just switch front with back). It's front wheel drive, so there's no axle on the back. Just trying to determine what to look at to see if it's bent. I put on air bags a while ago, and there was nothing obvious.
    Any easy way to check for a bent wheel? I guess the only way is to lift it and spin, then put it on a different corner and repeat. I suppose there is the possibility that the same wheel is on the same corner as the previous set of tires.
  5. Jul 20, 2012 at 12:46 PM
    DevilDogTacoma
    DevilDogTacoma Well-Known Member
    Maryland
    2010 Tacoma V6 DCSB
    Flowmaster 40 Muffler, 15% Front Window and Windshield Sun Strip Tint, Antennax 14" Antenna, OME 3" Lift w/AAL, SlimCubby 6000K HID headlights and foglights, Thule tailgate pad for surfboards, 285/70/17 Nitto Terra Grapplers on 17x9 XD Addicts, LED map, dome and tag lights
    Sometimes if you brake hard enough to make your vehicle go into a skid, it will leave a small bald patch on the tires which did the skidding. It's caused when the wheels are completely locked and the same patch of the tire is skidding across the roadway surface.
    That could be the cause.
  6. Jul 20, 2012 at 12:49 PM
    Schwinn
    Jamie
    Georgina, ON
    Not in this case...first tire was getting progressively worse until I changed it, and now this tire has the exact same spot. And it doesn't go all the way across the tread.
  7. Jul 20, 2012 at 12:49 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    He mentioned fighting with the dealership so I'm guessing it's relatively new...most cars on the road these days have ABS which acts to eliminate a locked up wheel skid during heavy braking.
