Odd Chirping Noise Inside Cabin – Only in Hot Weather, Engine Running
Discussion in '1st Gen. Tacomas (1995-2004)' started by yrmzzi, Jul 12, 2025.
  1. Jul 12, 2025 at 2:49 PM
    yrmzzi
    yrmzzi [OP] Active Member
    2001 Toyota Tacoma V6 - 4X4
    Hey all,
    Inside the cabin on the passenger side of my 2001 Tacoma V6 4x4, I’ve been hearing this odd chirping or squeaking noise. It almost sounds like a baby bird—but I’m sure it’s not!! The sound only occurs when the engine is running, and only in warm or hot weather, so I’m certain it’s mechanical in nature.
    My blower fan works perfectly, so I don’t think that’s the issue.
    Take a listen, this video was taken on the passenger side right under the glove box area....
    Has anyone else experienced something like this?
    Any insight would be much appreciated!
    Y
  2. Jul 12, 2025 at 2:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Does it change if you move the temperature ?
    yrmzzi[OP] likes this.
  3. Jul 12, 2025 at 3:08 PM
    yrmzzi
    I'll move the temp setting and try that and get back to you... I should add currently the temp setting is on "max cold" but my a/c system is not working right now as the magnetic clutch has failed and I have the fuse pulled and a/c pulley disconnected but I don't think this is related to the sound I am trying to diagnose
    HondaGM[QUOTED] likes this.
  4. Jul 12, 2025 at 3:08 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
