Odd chuffing sound from engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BulletProofKarma, Apr 9, 2023.
  1. Apr 9, 2023 at 4:59 PM
    BulletProofKarma
    BulletProofKarma [OP] Active Member
    2023 4x4 SR when idling the idle goes up and down, each time proceeded by a "chuff" that sound like air getting released or sucked in.
    Here is a video, right at 14 seconds you can hear it, sounds louder standing in front of the truck but not so loud in the video, any ideas?
    https://www.youtube.com/watch?v=d2Bo3eAUqbA
  2. Apr 9, 2023 at 5:03 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    v6 or inline 4?
    BulletProofKarma[OP] likes this.
  3. Apr 9, 2023 at 5:04 PM
    BulletProofKarma
    V6
  4. Apr 9, 2023 at 5:07 PM
    bluspectre
    bluspectre Active Member
    2007 Tacoma V6 4.0L Speed Auto
    Hey there! Based on the description you provided and the video, it seems like you might be experiencing some trouble with your idle control system. The "chuff" sound you hear is likely the engine trying to adjust its idle speed by either releasing or sucking in air.
    A few potential causes could be a faulty idle control valve, a vacuum leak, or a problem with the throttle body.
  5. Apr 9, 2023 at 5:11 PM
    Blak Shinobi
    taco
    n/a
    would it throw a code?
  6. Apr 9, 2023 at 5:22 PM
    bluspectre
    Anyone of those things could def throw a code.
  7. Apr 9, 2023 at 5:27 PM
    Blak Shinobi
    taco
    n/a
    or it could also be the Atkinson cycle switching from Otto cycle on the engine, when at idle the Atkinson cycle kicks in to be more efficient
  8. Apr 9, 2023 at 5:36 PM
    BulletProofKarma
    I don't have a code reader would it be obvious to me if it was throwing one? Like check engine light?
    Blak Shinobi likes this.
  9. Apr 9, 2023 at 5:39 PM
    Blak Shinobi
    taco
    n/a
    I personally feel like it would throw a code at you, but then again the other day I forgot to put the gas cap back on after 200 mile trip and it didnt throw a code at me , I would go to the dealer to see what is .Also keep in mind the v6 engine has port and direct injection, with atkinson cycle/ otto
  10. Apr 9, 2023 at 5:40 PM
    bluspectre
    Oh, sorry. I assumed there was a code being thrown. That's my bad!
  11. Apr 9, 2023 at 5:43 PM
    BulletProofKarma
    Well I posted in another thread about vibration in the steering wheel and gas pedal between 40 and 50 mph, took it to the dealer they drove around the block and said "everything is OK" friend at another shop said something is wrong, I suspect the dealer will see nothing wrong again.
    Less than 4k miles on it and I'm having a nervous breakdown over this truck.
  12. Apr 9, 2023 at 5:45 PM
    Blak Shinobi
    taco
    n/a
    dont worry man everything is going to be fine, sometimes my truck vibrates when slowing down when theres an incline , it could be the angle .If you start noticing everything on your truck your going to end up on valium
  13. Apr 9, 2023 at 5:48 PM
    Blak Shinobi
    taco
    n/a
    or worse trading it in for a Nissan:anonymous:
  14. Apr 9, 2023 at 5:51 PM
    BulletProofKarma
    I wish I had a valium.... my last truck was a 2002 tacoma, no problems, this one gives me the vibe it's going to be all problems.
    Thanks everyone for the suggestions it's off to the dealer (again).
    Blak Shinobi[QUOTED] likes this.
  15. Apr 9, 2023 at 5:52 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    They don't make them like they used and can have little quirks that weren't on older models. If you and another shop feel there is something wrong take back to the dealer and don't except there notion that nothing is wrong. They don't make much off warranty work so they try to avoid it. Keep on them and insist it is not right.
  16. Apr 9, 2023 at 6:00 PM
    Blak Shinobi
    taco
    n/a
    these trucks definitely need to some getting used to , show them the video that you posted on here
  17. Apr 9, 2023 at 6:01 PM
    BulletProofKarma
    I will, thanks again.
  18. Apr 9, 2023 at 7:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Go and spend $30 on obd2 adapter and fusion obd2 app w/toyota PIDs and you can calm your nerves down. That sounds like egr valve
  19. Apr 10, 2023 at 4:42 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Another one bites the dust. It's strange what these trucks can do some owners mind. I saw what it did to a buddy.
  20. Apr 10, 2023 at 8:35 AM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    I got that noise when i cleaned my throttle body for the first 10 minutes after fwiw
