Odd "clank" noise when braking...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iamsuperbleeder, Jan 22, 2013.
  1. Jan 22, 2013 at 8:10 PM
    iamsuperbleeder
    iamsuperbleeder [OP] Licensed Lunatic
    Travis
    Lake City, Florida
    06 DC Prerunner Taco - SOLD -
    TRD E-locker rear axle swap, Cherrybomb Extreme muffler, custom made CAI, 2.5" spacer lift up front and AAL's in the rear, Sport model seat swap, Pioneer X940BT, Kicker shallow 10" and 12" behind the back seat
    So for a while now I've been noticing a strange "clank" noise when applying the brakes. It only seems to happen when changing direction (forward to reverse, or reverse to forward) and then applying the brakes. It usually wont make the "clank" until the next time direction is changed.
    When it started, my first thought was worn out rear brake shoes that had a little play in the drum, partly because I actually thought the noise was coming from the rear. Well I swapped the ENTIRE rear axle assembly for one with an e-locker, and although the locker works fantastically :D the exact same noise was still present...
    So that narrows it down to the front...
    I had the front wheels off today swapping wheels, and I glanced at the pads just to check they're condition, and they at least look like they have plenty of life left on them, but I didn't really mess with too much and try to wiggle anything around or anything; didn't really have too much time to fool with it as it was getting dark.
    Has anyone ever had such a thing happen? If so, what did it end up being?
    If not, anyone have any ideas?
    It doesn't seem to have gotten any worse or better of the past 5 or 6 months.
    I consider myself pretty mechanically inclined and I have no problem exploding everything apart and fixing the problem, I just wanted to see if maybe there was something common that causes this on these trucks to give me a direction to go.
  2. Jan 22, 2013 at 8:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Floating front pads.......completely normal.
  3. Jan 22, 2013 at 8:14 PM
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Same problem with mine, lube the pins..problem solved my friend
  4. Jan 22, 2013 at 8:16 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    fantastic!
    thanks for the peace of mind fellas! :)
  5. Jan 22, 2013 at 10:17 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    X3 normal for sure. A 2nd gen thing
    Brett
  6. Jan 23, 2013 at 11:14 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Hopefully the above solved your issue; however, if it didn't then search this forum for 'Axle wrap'. From your description of your issue it sounds exactly like that might be the cause. You even mentioned that you swapped out your rear, check the fittings and bushings. There are many lengthy posts walking through fixes for axle wrap.
    -J
  7. Mar 22, 2014 at 10:28 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    What lube did you use?
  8. Mar 23, 2014 at 12:36 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
