odd clutch problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 350TacoZilla, Aug 1, 2010.
  1. Aug 1, 2010 at 8:20 AM
    350TacoZilla
    350TacoZilla [OP] Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    just got done putting tacozilla back together for road use (4cyl 4x4 5spd frame etc) and it needed a clutch so put in new match set clutch,pressure plate,throwout bearing,pilot bearing. when you press clutch down about 3/4 or so everything works fine, can take in and out of gear freely,truck rolls free etc.... push it all way down and its like the clutch is trying to engage, sticks in gear at a stop cant put it into gear if starting in N and truck tries to creep (forwards or back depending on gear)
    anybody ever had this after new install? I'm thinking maybe the master cyl or slave is bleeding off when pushed too far? any help is greatly appreciated
  2. Aug 2, 2010 at 2:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Did you mess with the pedal free play adjustment? If your master & slaves are in good shape not leaking etc; Try & bleed again & check the condition of your fluid also for discoloration,dirt & so forth.. good luck....:cool:
  3. Aug 2, 2010 at 7:04 PM
    350TacoZilla
    Hancock MD
    yeah all check drained, bled new fluid etc... like I said its an odd problem never had it before
