Odd Gear Oil Smell When Driving with Window Down
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Sep 14, 2019.
  1. Sep 14, 2019 at 6:43 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    Earlier this year while on a camping trip I noticed a peculiar smell when I rolled the window down a bit while driving. I first thought it was all the cowshit in the pastures but - no pastures or cows in the area. Smelled like gear oil was leaking from somewhere. I pulled over and checked all around underneath but found no leaks. Nor did I smell anything out of the ordinary. o_O
    Twenty miles farther I got a CEL. Wound up replacing my injectors to fix it, but the smell still exists. I can smell it whenever I drive over 20-30 mph. No other problems with the truck. If I keep the windows rolled up I don't smell it anymore.
    Has anyone else had a similar problem and if so, what was the cause?
  2. Sep 14, 2019 at 6:48 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    You probably have an air leak around your shifter boots. When you roll the window down, the cab becomes a low pressure spot and will suck air through any hole in the floor
    Wulf, Madjik_Man, otis24 and 3 others like this.
  3. Sep 14, 2019 at 6:48 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Sounds like it it time to get it nice and hot and spend some time laying underneath. Could be a whole bunch of things. Look for small oil leaks that may be dripping on top of the exhaust pipes. Stuff like that. Good luck.
  4. Sep 14, 2019 at 6:50 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Have you checked your fluid levels? Diff(s), transmission, transfer case, engine oil? How’s the drive shafts doing? Wheel bearings?
  5. Sep 14, 2019 at 6:57 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Check the rear and the sides of the valve cover/s for leaks, if they are and oil is getting on the exhaust manifold, you will very likely smell it, especially if the seals are getting old in the cab.
  6. Sep 14, 2019 at 8:26 AM
    skeezix
    Colorado
    1998 Limited
    Those were all good suggestions!
    I'll check for leaks around the shift boots. Never thought of that before. That might explain why I don't smell anything when I drive slower that 20-25 mph. Next, I'll crawl underneath while the engine is hot and look for burn spots on the exhaust.
    All fluid levels are normal. No other symptoms that I would know of that would indicate a wheel bearing or U-joint problem.
    I saw no oil seepage from the valve covers, or anywhere else when looking around from the engine compartment, and when I recently replaced the injectors I didn't see anything there either.
    @fxntime - Where are the cab seals that you wrote I should check?
  7. Sep 14, 2019 at 8:52 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Since you didn't say L4 or V-6, this advice is for V-6: check cam seals on the rear of the heads. It can drip right on top of the exhaust if they leak even a little bit. Just changed mine. Small extension mirror and light will be helpful.
    I think the "cab seals" was just a general reference to things like door opening seals, shifter boot, heater hose grommet to cowl, AC tubes, window glass runs, engine main wire harness to cowl, etc, etc. There are a lot of places sealed by rubber.
    Wulf likes this.
  8. Jul 28, 2020 at 11:15 AM
    coopjl
    coopjl Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    I’m curious if you ever figured this out?
    My 2014 does the same thing.
    It doesn’t have any leaks and it is definitely gear oil, not motor oil.
    Please let me know what you may have found
  9. Jul 29, 2020 at 8:43 AM
    skeezix
    Colorado
    1998 Limited
    Nope, I still smell it and I never figgered it out :rolleyes:
  10. Jul 29, 2020 at 8:53 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I can usually smell my CV boot grease when they tear. It doesn't smell quite the same as diff fluid. Also, you'd probably notice cv grease all over the place.
    Side note: no more torn cv boots since I did the boot slide mod a few years ago.
