Odd Noise After Turning Truck Off
Discussion in '1st Gen. Tacomas (1995-2004)' started by beignet, Aug 22, 2019.
  1. Aug 22, 2019 at 10:12 AM
    beignet
    beignet [OP] Well-Known Member
    Ben
    1996 3.4L 4x4 Tacoma
    I was skeptical of such a specialized shop at first, but after calling around a few places to get quotes on installing suspension components they came in near the lowest, and encouraged me to buy my shocks from elsewhere at a good price I'd found since they couldn't match it through their distributor. Even now they said I don't need to replace the EVAP, that it's just singing its little tune.
    GQ7227[QUOTED] likes this.
  2. Aug 22, 2019 at 10:13 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Ahh makes sense then why I don't hear it on my 04
    GQ7227 likes this.
  3. Aug 22, 2019 at 10:15 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Thanks for letting us know, learn something new everyday. Mine was fairly high mileage but never did anything that sounded like that, even on the hottest of days.
    Ride on sir!
    jeff
  4. Aug 22, 2019 at 10:17 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Retrofitted box, note the little "stem" between the box and canister, not seen on the factory version.
    beignet[OP] likes this.
  5. Aug 22, 2019 at 10:25 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Probably cause yours is under the bed. 01 was the last year to have it under the hood. It's not very loud, you probably have to stick your head under the truck to hear it. As said, usually only makes noise when it's hot and/or your tank is pretty empty.
    eon_blue[QUOTED] likes this.
  6. Aug 22, 2019 at 10:27 AM
    beignet
    Ben
    It might be haunted yet. I was poking around under the dash the day after I bought the thing trying to assess if the e-brake switch was working. There was an old CB coax cable tucked under there that fell out right smack into my eyeball, resulting in an urgent care visit. I've been treating the truck with a healthy dose of respect lest it try to maim me again.
  7. Aug 22, 2019 at 10:29 AM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Previously owed by Stephen King, apparently...
  8. Aug 22, 2019 at 10:31 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I only hear that noise on my during the Summer months here in the Desert or after long drive on the Freeway
  9. Aug 22, 2019 at 10:59 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Now that you mention this, I am the same way, specifically with the supercharger. Idle sounds normal, high RPM sounds normal. Under load below 2k up to 2500 though always sounds “noisy”.
    Its been doing this since brand new. And it’s not ping, I was able to tune that out. It just makes noise and it isn’t a smooth, consistent noise in that area. Have you experienced this?
  10. Aug 22, 2019 at 11:20 AM
    eon_blue
    Azusa, CA
    Hm, I'm not sure about that one...I do get bad sounds from 2k - 2.5k but it's definitely pinging. If I hit too much boost under 2.5k it'll ping especially if it's hot outside. I don't think my 7th injector starts adding fuel until around 2.5k RPMs + boost
  11. Aug 22, 2019 at 11:27 AM
    96towcoma
    96towcoma Well-Known Member
    james
    1997 single cab 4x4
    From what I understand Unless you have it set up right it does nothing in closed loop. so once your truck warms up it’s not going to help the ping. Unless yours has the closed loop capability
  12. Aug 22, 2019 at 11:32 AM
    eon_blue
    Azusa, CA
    I only get pinging in open loop, but the issue is that even in open loop it won't add fuel until it senses a certain amount of load (I believe) which usually happens around 2.5k RPM. If I go WOT at 2.5k RPM (or higher), no pinging...if I go WOT at say 2k or 2.3k RPM then I'm in ping city and have to back off the throttle.
    Another member on here sent me a file for the 7th injector that tunes it differently to add fuel earlier on but I haven't figured out the logistics of customizing it yet to add that tune. That's a whole other topic lol
  13. Sep 7, 2021 at 5:25 PM
    chirkin
    chirkin Well-Known Member
    james
    yosemite ca
    1996 tacoma xcab 4x4
    ome 5100 up front ad leaf in rear 31 inch tires
    thanks for putting this info out here just had a rebuilt put in my truck and noticed the same noise it had me freaking out haha not anymore.
  14. Sep 7, 2021 at 5:42 PM
    beignet
    Ben
    Yeah, man! My truck now has another three years and 40,000 more miles on it from when I originally posted this thread. The frog still visits in the summer, but the EVAP system hasn't given me any problems otherwise since the initial post. Glad to hear that someone benefited from my worrying about the noise!
  15. Sep 7, 2021 at 9:14 PM
    #35
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Still sounds like a bad solenoid but if it works it works :notsure:
  16. Sep 7, 2021 at 10:29 PM
    #36
    Glamisman
    Glamisman Well-Known Member
    it is your evap canister. On later years they moved it to by the fuel tank. Next time it does it take you fuel cap off the relieve the pressure and the sound will go away.
    chirkin and Laxtoy like this.
