Odd noise from rear of truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 14TACO4X4, Oct 10, 2014.
  1. Oct 10, 2014 at 8:42 PM
    14TACO4X4
    14TACO4X4 [OP] Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I went out into my garage to grab something and heard a humming noise. Sounded like a small compressor or something and I thought maybe it was outside, so I went outside and did not hear it... had to be coming from in the garage (door was closed). So I go back into the garage and walk around, finally crawling under my truck where it got louder.
    My truck was off and cold. I hadn't driven it for over 8 hours. The keys were not in it, and it wasn't on. Something was humming like a small pump or compressor or something. Then it abruptly stopped.
    It was from the middle or rear part of the truck... what the hell is back there that would make any sound like that, or cycle on and off even when the truck is off and cold?
  2. Oct 10, 2014 at 8:46 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Fuel pump keeping lines primed.
  3. Oct 10, 2014 at 8:51 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2
    Welcome to the future. Where everything is controlled by software and nothing really ever turns "off".
  4. Oct 10, 2014 at 8:53 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Thanks guys. Had never heard it before, so I was like... WTF is that sound!?
  5. Oct 10, 2014 at 9:31 PM
    Taco'09
    Taco'09 Well-Known Member
    Your evap. emissions system is running a check. The ECU is commanding a a vacuum pump to run an look for leaks. Its usually hours after the truck is turned off. Wait until you are working on the truck sometime when that thin starts to run and do its thing.
  6. Oct 10, 2014 at 9:56 PM
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    Yup, it's your emissions system doing a self check. Some systems require certain parameters to be met before the ECU initializes a systems check. For instance, if you never take your vehicle up to freeway speeds, you'll never pass SMOG, because the vehicle never met the parameters for the self check.
  7. Oct 11, 2014 at 11:00 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Now that is interesting!! I was not aware of this. As I'm driving less as I get older I'll try to get this on the highway occasionally and especially before I get an emissions check.
