odd noise from speedometer
Discussion in '1st Gen. Tacomas (1995-2004)' started by RandomBassist, Feb 21, 2010.
  1. Feb 21, 2010 at 7:57 PM
    RandomBassist
    RandomBassist [OP] New Member
    florida
    95 2.4l
    Hello all I recently purchaced a 95 taco 2.4l and i love it. Problem is this however. Sometimes the truck has and odd rythmic squeak from behind the dash. it speeds up when I accelerate and slows down when braking. I think it has something to do with the speedometer because as the sound is occuring the needle wobbles slightly. Hopefully somebody else has had some experience with this. Thanx in advance for any thoughts
  2. Feb 26, 2010 at 9:37 AM
    mgeoffriau
    mgeoffriau Member
    Mark
    Ridgeland, MS
  3. Feb 26, 2010 at 9:40 AM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Had a problem on my 89, squeek turned out to be speedometer cable. might want to check that
  4. Feb 26, 2010 at 9:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    If your speedo is bouncing you may need a new cable and drive gear.
  5. Feb 26, 2010 at 11:35 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Yep - sounds like a classic case of speedo cable issues ...
  6. Mar 6, 2010 at 11:26 AM
    RandomBassist
    florida
    95 2.4l
    thanks for the replies guys. Is the speedometer something thats going to be a royal pita or is it relatively simple? Im used to working on a lincoln, so i dont assume that anything will be easy.
