Odd noise from under glove box.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bergey, Jan 21, 2017.
  1. Jan 21, 2017 at 1:11 PM
    bergey
    bergey [OP] Member
    '13 Tacoma TRD Sport [Pyrite Mica]
    Kelly Safari TSR [P265/65/R17] Bilstein 5100
    I am slightly stumped by a noise I hear under my glove box, only during a certain scenario. The vehicle is a 2013 Tacoma.
    When I have my blower motor on setting 3 or 4 and the vehicle is mobile, if I press the brakes I hear what sounds like the blower fins hitting plastic. I took the blower out and it wasn't loose, worn or damaged - same goes for the housing it mounts to.
    I'm completely stumped but the noise is driving me insane in the mornings.
  2. Jan 21, 2017 at 1:21 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Did you check above where the filter is. Sometimes sticks or leaves handle down. The other thing it may be is the bearing beginning to wear. Earlier models had problems with the blower motor squeaking and chirping from prematurely worn bearings.
