Odd noise in RF wheel area? HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lawdwaz, Nov 26, 2011.
  1. Nov 26, 2011 at 4:58 PM
    Lawdwaz
    Lawdwaz [OP] Member
    Larry
    WNY
    2011 4x4 SR5 DBC
    I thought I'd ask the guys in the know.....I have a 2011 DCLB 4x4 and when I put it in gear for the first time after a start-up I get a strange sound that sounds like the flaps on an airplane being adjusted?? It's short, only does it for a second, sounds like something engaging or disengaging?? It's in the area of the front passenger side wheel area I believe.
    What do you think?? Thanks!
    (I have about 7,500 miles)
  2. Nov 26, 2011 at 5:07 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    ABS check
  3. Nov 26, 2011 at 5:08 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    I've heard mine make this noise when the 4WD is disengaging.
  4. Nov 26, 2011 at 5:09 PM
    Lawdwaz
    Lawdwaz [OP] Member
    Larry
    WNY
    2011 4x4 SR5 DBC
    Do you mean "check the ABS"?
  5. Nov 26, 2011 at 5:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    x2
    it's the ABS thingy purging itself and doing a functions test and all that jazzy stuff
  6. Nov 26, 2011 at 5:12 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    It's doing an ABS self check. Sorry i wasn't more clear.
  7. Nov 26, 2011 at 5:13 PM
    Lawdwaz
    Lawdwaz [OP] Member
    Larry
    WNY
    2011 4x4 SR5 DBC
    Nothing to be concerned about then?
  8. Nov 26, 2011 at 5:17 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    no sir.
    some seem to be louder than others. If this is the area your hearing it from with the parameters you are speaking of then it's a self check.
