Odd OBDII port problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcm79, Jun 30, 2014.
  1. Jun 30, 2014 at 5:34 PM
    bcm79
    bcm79 [OP] Member
    Brian
    Mesa, AZ
    07 DCSB
    OME 886, AAL, 33's, ARB, etc...
    Hi all, I'm at my wits end with my truck (07 DC 4WD) and hoping someone can offer some advice:
    I usually have a ScanGauge hooked up to the OBDII port, which has been working fine. Took the truck in to have a smog check done, and the tech could not get their scanner to communicate with the truck. They even tried another scanner and called in their supervisor, with no luck.
    Hooked the ScanGauge back up, no problem. Took the truck to O'Reilly's to see if their scanner would work..no luck there either.
    Checked all the fuses in both fuseboxes, and everything is good. All the pins on the connector look fine.
    Any suggestions before I take it to the dealer?
    Thanks!
  2. Jun 30, 2014 at 6:02 PM
    smd3
    smd3 Well-Known Member
    There's a few other posts about this, although I'm not sure how they had it resolved. It seems to be more of an issue with the garages scanner than the truck iirc.
  3. Jun 30, 2014 at 9:19 PM
    bcm79
    bcm79 [OP] Member
    Brian
    Mesa, AZ
    07 DCSB
    Thanks, I found a couple of references but it doesn't seem like anyone ever got full resolution, or at least didn't post the final outcome. My first thought was something was bad with the emission's test facilities' scanners or their tech/supervisor, but I think I ruled that out by the trip to O'Reilleys, whose scanner worked just fine on another car in the lot.
    At this point I'm suspecting an issue with the connector in the truck, like maybe the pins on the Scanguage stretched out the connector contacts.
  4. Jun 30, 2014 at 9:24 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I had the same prob but it was my OBD fuse, did you find the ODB fuse under the hood ? Most scanners are not self powered which is why it will not work if the fuse is popped so the port itself is not supplying power.
  5. Jun 30, 2014 at 11:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If that were true his Scangauge wouldn't work either. It is also powered by the OBD2 Port.
  6. Jul 21, 2014 at 8:38 PM
    bcm79
    bcm79 [OP] Member
    Brian
    Mesa, AZ
    07 DCSB
    Figured it out last week. Posting this just in case anybody else has the same issue.
    Took it to the dealer (2nd trip in a dealer service bay in 100,000 miles) for them to investigate. Their scanner, actually three different scanners, worked just fine. No charge for them to check it out.
    Took it to a different smog check station. No luck, still failing, smog test staff was slightly less than useless.
    Removed the connector from the plastic housing, and found that the middle two pins (data pins) on the Scanguage appeared to have pushed the pins on the connector back about 1/16". I opened up the flaps on the connector, and reseated all of the pins.
    Took the truck to O'Reilley and this time their tester made a connection.
    Put the connector back in the housing, returned to the original smog station, and FINALLY passed.
    scocar, brucehutchinson and CJVant like this.
