Odd observation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DanSharp, Dec 12, 2019.
  1. Dec 12, 2019 at 6:09 PM
    DanSharp
    DanSharp [OP] Well-Known Member
    Dan
    2020 White Tacoma
    All,
    Noticed when I am in park, if i turn the steering wheel the rpms go up a bit. I remain at a constant idle but if I wheel left or right the rpms increase a bit then drop down. Anyone else notice this?
    Thanks,
    Dan
  2. Dec 12, 2019 at 6:10 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yep. To help with steering.
    Chew and DanSharp[QUOTED][OP] like this.
  3. Dec 12, 2019 at 6:11 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Yea because your engine is under strain from the extra load of your power steering pump as you turn the wheel and the ECU increases RPMs to compensate
  4. Dec 12, 2019 at 6:14 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Just like a bump in idle when the AC compressor kicks in :thumbsup:
    Chew, davidstacoma and DanSharp[OP] like this.
  5. Dec 12, 2019 at 6:17 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Pretty cool isn’t it. Not so good for tires but the ecu helps you out.
    DanSharp[QUOTED][OP] likes this.
  6. Dec 12, 2019 at 6:18 PM
    Bishop84
    Bishop84 Well-Known Member
  7. Dec 12, 2019 at 6:32 PM
    DanSharp
    Dan
    2020 White Tacoma
  8. Dec 12, 2019 at 6:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Google is your friend. If you use 3rd gen Tacoma in your search it will give you the correct thread here.
    Chew likes this.
  9. Dec 12, 2019 at 7:05 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Power steering... I thought. However, I used to as reason to get a TSB tune, and the dealership bought it.
  10. Dec 12, 2019 at 7:05 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Google searches "tacomaworld Google is your friend" gets 100,000 hits
    Chew and Skydvrr like this.
