Odd problem with brake lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragsterhund, Jan 17, 2016.
  1. Jan 17, 2016 at 10:10 PM
    dragsterhund
    dragsterhund [OP] Member
    Charlie
    Washington DC
    2005 Access Cab V6 4.0L
    I found out today that on my 2006 Tacoma, all three tail lamps work (left, right, and the high mount lamp above the bed on the back of the cab) turn on, but only the brake light on the cab illuminates when I hit the brakes. It's the same light bulb in the taillights for both brake lights and tail lamp functions. Would there be a relay that increases the voltage to the bulbs when the brake pedal is depressed between the cab lights and the taillights that I should check?
  2. Jan 17, 2016 at 10:22 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The bulbs are a dual filament - lower wattage for the tail light, higher wattage for brake light, essentially two bulbs contained in one, thus the three wire connection. In your case the higher wattage filaments are not working - either both are burnt out, or there is an issue with the brake light power to the rear of the truck.
    robssol and Jimmyh like this.
  3. Jan 18, 2016 at 6:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This ^^^^^^^^^^^^^
  4. Jan 18, 2016 at 6:25 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Wow, better take it to the dealer to get it looked at
  5. Jan 18, 2016 at 6:26 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Have you tried changing bulbs in the taillights?
  6. Jan 18, 2016 at 11:21 AM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    The OP is asking for help to diagnose the issue, that's one of the benefits of being on a forum. Troubleshooting lights is not that difficult and the OP should explore all options before taking it to a dealer.
  7. Jan 29, 2016 at 6:06 PM
    dragsterhund
    Charlie
    Washington DC
    I had no idea there were two filaments in the bulbs, so yeah, the brake filaments in both bulbs were burned out. In my defense, I checked both with a spare bulb (which, going back and looking, turned out to be a single-filament bulb, so of course that didn't help diagnose the problem), before I posted on here. Same base, but single filament. Also, I've never had two lights go out at the same time, which made me thing the problem was more serious than just burned out bulbs. Thanks!
  8. Jan 29, 2016 at 6:28 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Win-win - you learned something new, and fixed your truck without great expense. Thanks for the update.
  9. Jan 29, 2016 at 6:34 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    unlucky BOTH bulbs went bad at the same time...if it happens again then you have some other electrical issues....
  10. Jan 30, 2016 at 4:23 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Just a thought...is it possible that you had one burned out brake light for a while before the other one went out, and you just didn't happen to notice it?
    I see that a lot more then people might think, cars and trucks running around with just one brake light working...
