Odd question,
Discussion in 'Garage / Workshop' started by Lukass, Oct 31, 2020.
  1. Oct 31, 2020 at 9:31 PM
    Lukass
    Lukass [OP] Well-Known Member
    Luke
    Payson Arizona
    Extraordinarily Stock ‘99 Tacoma TRD
    Bilstein 5100’s
    Whether it’s practical or not. Let’s say you’ve got all the money all the time and patience in the world, could you slap a turbo on your Taco, change out some fuel delivery stuff and then run diesel through your rig?
    wilcam47 likes this.
  2. Oct 31, 2020 at 9:35 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Diesel, no, turbo yes.
    Diesel needs direct injection and a mechanical high pressure pump, the 1GR cannot handle compression combustion pressures and uses indirect fuel injection.
    You could convert to liquid propane if you wanted though.
    ColtsTRD and Lukass[OP] like this.
  3. Oct 31, 2020 at 9:38 PM
    Lukass
    Luke
    Payson Arizona
    Bilstein 5100’s
    So if you had an engine with direct injection and an engine that can handle the compression than yes?
  4. Oct 31, 2020 at 9:40 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yes
    ColtsTRD, Lukass[OP] and 0xDEADBEEF like this.
  5. Oct 31, 2020 at 9:42 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  6. Oct 31, 2020 at 9:42 PM
    Key-Rei
    Key
    Florida
    Yes if you put a diesel engine in (and mating trans that can handle the torque low RPM and communicate with the engine ECU, or just a built manual trans) then yes the fuel lines and tank can handle the diesel, you may need a different fuel filter though.
    Lukass[QUOTED][OP] likes this.
  7. Oct 31, 2020 at 9:49 PM
    Lukass
    Luke
    Payson Arizona
    Bilstein 5100’s
    Cool thanks dude
  8. Nov 6, 2020 at 1:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you have a unlimited budget why not do a Diesel Swap and be done
    JMcFly likes this.
