Odd ringing sound underneath truck...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bz3r0, Jun 18, 2011.
  1. Jun 18, 2011 at 6:59 PM
    Bz3r0
    Bz3r0 [OP] Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    Hey guys, not sure if there's a thread already started for this.... If so, a moderator can take this down.
    I own a 2010 Prerunner Sport, and it when I drive over any type of terrain that causes vibration, (anything vs. smooth road) I tend to hear a "ringing" sound from beneath my truck. (It would be best described as loose change jingling in a pocket) Any thoughts to what this may be? Anything I may be able to tighten up underneath that would stop this?
    I haven't gotten underneath the truck in an attempt to check what may be "loose" or could sound like pocket change when rattled.
    Thanks for your input!
  2. Jun 18, 2011 at 9:27 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I remember someone on here with kind of the same issue...ended up being a loose skid plate. Aslo maybe spare tire is loose and hitting something?
  3. Jun 18, 2011 at 10:21 PM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Just pulled skidplate off last week and Plasti-dipped it... Made sure that s.o.b. was tight. I'll check the spare tire... but it sounds like its coming from underneath the cab of the truck. Its extremely audible when my windows are down.. might try and catch it on film tomorrow... Almost wish i had a gopro camera to mount underneath...
  4. Jun 18, 2011 at 11:18 PM
    TJ Asher
    TJ Asher Well-Known Member
    TJ
    Minneapolis
    '10 Virgin
    I had a similar issue. Turned out a shield for gas tank was bent and rubbing on driveshaft.
  5. Jun 19, 2011 at 6:38 AM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Fuhhh, ill have to check and see if that's the issue.... Thanks
  6. Jun 19, 2011 at 6:42 AM
    Chainsmoker
    Chainsmoker Well-Known Member
    Ed
    Phila.PA
    09 Tacoma 4x4 double cab Short Bed
    3inch ProComp Lift. 285/70/17 on ATX Crawl wheels. tinted windows. blacked out tail lights. 8k hid fogs. projector headlights with dual halo rings and 8k hid. remote start. blacked out grille.
    LOL... I hit a massive puddle/pond going down the highway and after that I had the same issue. But it would only rub when I would accelerate. took me almost 2 days to figure it out.
  7. Jun 19, 2011 at 6:44 AM
    Chainsmoker
    Ed
    Phila.PA
    And it did sound almost like a loose change
  8. Jun 19, 2011 at 9:05 AM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Just got out from underneath the truck, and all of the heat shields and the gas tank looked g2g... i tried to duplicate the sound using the side of my hand by hitting a few things, to no avail. I can't induce the amount of vibration to make it sound off... Any other ideas would be greatly appreciated!
  9. Jun 19, 2011 at 9:52 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Look just rear of both LCA's, there is a round body mount i believe, and it can hold rocks and other loose items from the road. Maybe something in that?
  10. Jun 19, 2011 at 9:57 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine does it....i ignore it
  11. Jun 19, 2011 at 10:00 AM
    utahskierdave
    utahskierdave Well-Known Member
    salt lake
    08 tacoma dbl cab
    I am thinking I have the same issue...sounds to me like it's under the passenger side and slightly forward and I am guessing it's some sort of heat shield. Doesn't bother me enough to get under and look but if you find the problem let me know!
  12. Jun 19, 2011 at 10:14 AM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Will do... if I find it... haha.
  13. Jun 19, 2011 at 12:06 PM
    bagster
    bagster Well-Known Member
    Gravel inside your brake drum, maybe?
  14. Jun 19, 2011 at 12:09 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    the only time i had the noise is when i had a shit ton of mud underneith <sp? my truck...
  15. Jun 19, 2011 at 12:37 PM
    Lukin
    Lukin Active Member
    New Jersey
    2011 DC TRD Sport
    Mine rattles over bumps. Apparently it's brake rattle from the front brakes. It stops as soon as I touch the brakes. I've tried everything to resolve it and can't.
  16. Jun 19, 2011 at 4:37 PM
    Chainsmoker
    Ed
    Phila.PA
    Now that i think about it. After a few trips wheeling i started to get a strange sound that seemed to come from the driver side front end and it almost sounded like something was loose. i was a bit concerned that my wheel was gonna fall off or something. But anyway when I put my windows down to listen the sound would go away and I was lost. Later i found out it was my driver side mirror. There was some dirt inside making the noise.
  17. Jun 19, 2011 at 10:12 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    does the noise get faster when you rev the truck higher? does it go faster or slower if you change speed? or is it always the same jingle no matter what?
  18. Jun 19, 2011 at 10:21 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I started hearing this after toyota replaced my tranny.. I was kinda worried and thinking of taking it in again.. but I am glad to see this thread with multiple people (auto tranny included) having the issue.
  19. Jun 20, 2011 at 2:25 AM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    Same jingle no matter what, and only noticeable at low speeds because of other road noises. It doesn't get louder with engine rev.
    I'll get back underneath and poke around after i get off of work... Thanks for all of the other suggestions fellas!
  20. Jun 21, 2011 at 4:54 PM
    kevintuckerman
    kevintuckerman Member
    kevin
    Eastern PA
    05 Taco SR5 w/toytec front end
    I have had the same ring forever. it generally happens when keeping a constant speed/rpm. (doesn't matter what speed or rpm). but goes away on harder acceleration and breaking. I think it is tranny related but not certain.
    KM
