Odd Rough Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Smiley, Jan 10, 2018.
  1. Jan 10, 2018 at 1:32 AM
    Mr.Smiley
    Mr.Smiley [OP] Well-Known Member
    Zach
    Santa Rita, GU
    2015 Black Tacoma TRD OR DCSB 4x4
    Bone Stock
    Hey guys, a little help needed.
    So with my 2015 Tacoma it'll rough start every once in a while. It is always after the truck sat for atleast 4 hours. The only way to predict it happening is the truck will idle slightly rougher than normal prior to turning it off. It's barely noticeable but it's still there.
    I was thinking probably just a simple issue like spark plugs, but the truck is only 3 years old and has <20k on it. So I'll probably throw some new plugs in this weekend, but was wondering if you all have any other suggestions. TIA!
  2. Jan 10, 2018 at 2:39 AM
    rpkean
    rpkean Well-Known Member
    Macomb, MI
    TRD Supercharger
    I had the same issue. Found out the battery was draining due to leaving one of the interior lights on.
    The dealer fully recharged the battery and I haven’t had an issue since.
    Also note, this was really only happening during the winter when it was cold.
  3. Jan 10, 2018 at 3:10 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    If you rule out battery issues, maybe clean the MAF sensor and throttle body when you get a chance and change air filter also. I’m thinking with only 20,000 miles in 3 years its a little gunky, dump a can of Seafoam in the gas tank, get it on the highway for a while and stretch its legs...
    Those are all cheap easy DIY things to look for before you dig into it further.
