Odd shudder at 25mph
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtrguy, Mar 21, 2013.
  1. Mar 21, 2013 at 10:35 PM
    vtrguy
    vtrguy [OP] Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    Installed a 1.5" AAL while waiting for my leaf packs to get here in order to compensate for having my new camper and a couple of other goodies in the back.
    Now, when cruising at a steady 25mph there is an odd shudder through the whole truck and low rumble that matches the intensity and speed of the movement.
    The ride/noise goes away as soon as you get over 30 and it doesn't track during high or low speed driving or braking.
    There is very slightly increased steering input (might be me just being a hypochondriac, this is more than likely).
    When installing the AAL I did have to leave one wheel/leaf pack attached so when raising the axle back up I did have to tweak the axle a little in order to get the alignment pin to line up correctly (about 1/2- 3/4" forward on both sides)
    As I purchased the truck 4 months ago I couldn't tell you when the last alignment was done. Could this be the culprit and adding a leaf just compounded the problem?
    Any input is greatly appreciated.
  2. May 25, 2013 at 9:44 AM
    sailtaco
    sailtaco New Member
    03 2.7 4WD
    Stock
    Check the driveshaft. If you're 4WD you can drop the drive shaft and run in 4WD. If the shudder goes away, the drive shaft is bent or needs balancing.
  3. May 25, 2013 at 10:00 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I've been chasing a similar vibration at that speed since I got my 96 last fall. It's all stock but it's got 260k on it. I'm almost positive it's the actual driveshaft. I've replaced the carrier bearing and a few u-joints and it got way better, but it's still there.
  4. May 25, 2013 at 10:18 AM
    sailtaco
    sailtaco New Member
    03 2.7 4WD
    Stock
    How much did you pay for the carrier bearing? Mine seems shot.
  5. May 26, 2013 at 10:06 AM
    85GT 79FJ40
    Ken
    New Hampshire
    I don't remember honestly. Bought it from Rockauto. Probably under 50 bucks.
  6. May 26, 2013 at 10:15 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Be sure to check the angle of your u joints too. U joints at too high of an angle can shudder like that. If any of your rear u joints look too angled you can add some washers as spacers above your carrier bearing and see if it gets better.
  7. May 26, 2013 at 12:11 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    This, don't go replacing your driveshaft or carrier bearing until you try this! Otherwise you're probably wasting your money on a part that didn't need replacing.
