Odd starting Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by KEEP IT RUNNING, Jan 9, 2016.
  1. Jan 9, 2016 at 12:20 PM
    KEEP IT RUNNING
    KEEP IT RUNNING [OP] New Member
    2004 Toyota Tacoma
    Stock and only 50K miles
    I bought this 2005 Toyota Tacoma from my brother in law after he was told it needed a new engine by his Mechanic. It only has 50k miles on it and Looks near new.
    The compression is good, not like the Mechanic told Him.
    I can start it if I add fuel by means of a vacuum line directly into the intake manifold.
    Once started it runs great, but will not restart the next morning.
    Where do I start looking??
  2. Jan 9, 2016 at 2:33 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Not sure about the 2005 models, but in my 1999 3RZ, the fuel pump will not turn on until it receives a signal that the starter motor is cranking. Not sure what generates that signal, though. That would be one place to look.
    KEEP IT RUNNING[OP] likes this.
  3. Jan 10, 2016 at 8:58 AM
    KEEP IT RUNNING
    2004 Toyota Tacoma
    Thank You tan4x4
    I will fallow up on your suggestion and keep you posted.
    I previously owned a 1999 4x4 Tacoma with nearly 300k miles on it. after selling it I realized i will always need a truck so I jumped at the chance of getting this one with only 50k miles on it and I know the previous owner. I do 90 percent of all my own work on my vehicles. I'm a machinist by trade. But this has been one of those puzzling problems.
    The sad thing is, I believe the Mechanic completely miss diagnosed the problem and may have tried to take advantage of his customer. Which ended up being a good deal for me.
    I will not share the Mechanics business name until I am sure of the problem and fix it. But he is near your location. of Folsom Ca.
    Thanks again
