Odd Tire Wear, Only One tire
Discussion in 'General Automotive' started by LeftyTom, Oct 6, 2012.
  1. Oct 6, 2012 at 8:14 AM
    LeftyTom
    LeftyTom [OP] Well-Known Member
    Yadkinville NC
    2011 Tacoma AccessCab, 2WD, 5spd, SR5
    I had the tires rotated on the wife's 2001 Camry (149K miles) this morning. The rear tire on the driver side has noticeable wear on the inner tread. Not to the point of being slick or belts showing, but you could easily see the difference. The other 3 tires all had normal wear across the treads. These are Michelins with about 50K miles on them; all replaced at the same time.
    The only suspension work that has been done is both ball joints were replaced last year. I had it aligned then.
  2. Oct 6, 2012 at 12:44 PM
    LeftyTom
    Yadkinville NC
    Forgot to mention that the air pressure was OK in all tires.
  3. Oct 6, 2012 at 12:52 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Betting its out of alignment
  4. Oct 6, 2012 at 12:54 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    x2......maybe your wife didn't tell you about that huge pot hole she ran over :confused:
  5. Oct 6, 2012 at 12:56 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Inside tire wear is camber issue.
  6. Oct 6, 2012 at 1:10 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    X2
  7. Oct 6, 2012 at 3:32 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Any unusual noise or bottoming out with that rear end...
    We have had 2 Camrys with irregular rear tire wear and both times it was "tired" rear struts but both were older models...My '92 & '95 each had over 100k....'92 had bad cupping plus dead bump while the '95 took the inside of tire and "rolled" into hard corners...
  8. Oct 6, 2012 at 3:42 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not familiar with the Camry suspension, but it may also have a toe adjustment on the rear, but yes... that would cause feathering more than extreme wear on the inside.
  9. Oct 6, 2012 at 4:56 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    What kind of pattern of wear is there? i.e High/Low spots? Balding but even wear?
    -Check balance (more than likely not your cause, but any tire wear issue should start with a simple, is it balanced or not, check)
    -Check alignment (rear toe is adjustable on the camy)
    Do these few things and check back.
  10. Oct 13, 2012 at 5:25 AM
    LeftyTom
    Yadkinville NC
    Chris, it is uneven wear; inside tread (2" wide from inner sidewall) more worn than rest of tread.
    I had the alignment checked OCT12. Turns out the toe was a bit out.
    Thanks for the replies, all.
