Odd trailer lighting issue just occurred
Discussion in 'Towing' started by anders99, Oct 2, 2013.
  1. Oct 2, 2013 at 8:46 PM
    anders99
    anders99 [OP] The Sailing Member
    Matthew
    Niceville, Florida
    07 Base 4cyl 4x4
    SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake
    So Sunday I was towing my boat. Lil boat no more than 400 lbs behind me. Anyways when i turned on my turn signal my dash and radio started to flash with the signal. When I hit the brakes same thing they would dim. What would cause this issue
  2. Oct 3, 2013 at 7:47 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    I have never heard of that. Is it a new truck? Has it worked in the past, or is the the first time towing with this truck?
    I would get another trailer that you know works fine, or hook your trailer up to a buddy's truck that you know works fine and try to figure out if the problem is in the trailer or the truck.
    Are you under warranty and able to duplicate the problem?
  3. Oct 3, 2013 at 8:06 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    13 Access 4x4 TRD Offroad
    Empty gas tank mod
    Ground short. Is this a plug and play trailer wire harness?
  4. Oct 3, 2013 at 8:09 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    I would bet the issue is on the trailer. Watch to be sure it only happens when trailer is hooked up. When it does happen unplug the trailer to see if it stops
  5. Oct 3, 2013 at 8:36 AM
    anders99
    Matthew
    Niceville, Florida
    07 Base 4cyl 4x4
    I have towed many times with this and no problems. I think it is the trailer. It is about that time of year again for some new lights.
    Yes its a plug and play. I will check the ground spot for a bad connection.
    I think its the trailer because it is only when the trailer is hooked up. I have played with the plug on the trailer side and I think that is where the problem is
  6. Oct 3, 2013 at 7:42 PM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    I have heard of the control box on the aftermarket trailer wiring going bad, before redoing your trailer lights I would hook up to a different trailer to make sure it's the lights.
  7. Oct 3, 2013 at 7:44 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That will usually cause problems when the trailer is not plugged in.
  8. Oct 3, 2013 at 8:14 PM
    anders99
    Matthew
    Niceville, Florida
    07 Base 4cyl 4x4
    The box is good just pulled another trailer today preparing for Tropical Storm Karen and no issues.
