Odd vibration.......
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtmccray, Feb 17, 2012.
  1. Feb 17, 2012 at 4:04 PM
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Hey I have an 01 dc,trd,v6. At about 25 mph I'm getting a vibration it gets worse up to 30-33 mph then get progressively less as you increase speed with it being the worst at about 30 mph. It feels like its coming from the front more than anywhere else. I seems to shake the whole truck. At 30 its pretty bad once you hit 35-40 and up its not as bad but bad enough to be annoying. It doesnt matter if you are in 4wd or 2wd its about the same. Steering wheel doesnt shake. My first thought was hanger bearing, it had a more play than I thought it should so I replaced it....didnt help. Jacked the front end up wheels/bearings seem tight no play side to side or up and down. C/v shafts are tight a little play at the differential but that is normal isnt it? Possibly a out of balance tire but that should shake the wheel shouldnt it? Any Ideas? Maybe rotate the tires and see If that changes anything?
  2. Feb 17, 2012 at 4:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No recent lifts, suspension upgrades or anything like that ?
  3. Feb 17, 2012 at 4:52 PM
    dtmccray
    millbrook alabama
    01 money pit
    bought it 2 weeks ago everything is stock as best I can tell.
  4. Feb 17, 2012 at 5:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Hmmm, well yeah, I reckon that tire unbalance,or alignment could be an issue, ya just gotta start from most likely to least I guess.
    As far as the carrier bearing goes, even Toyota doesn't have specs. as far as slop goes.
  5. Jul 21, 2012 at 7:11 AM
    toyotadan98
    toyotadan98 Well-Known Member
    wa
    2011 TRD OFFROAD 4X4 ACC
    simular to my truck ,i replace the rear u-joints and it made the vibration even worse than before????my truck is a trd 4x4 all stock so i am confused as to what could be causing my vibration.
  6. Jul 21, 2012 at 10:17 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Did you remember to mark your flange/bolt where it connects ? It's pretty important that the shaft bolts up to its original location....;)
  7. Jul 21, 2012 at 3:31 PM
    dtmccray
    millbrook alabama
    01 money pit
    When I put my drive shaft back together it was one spline off,but the problem was one of my tires. I had them rotated and balanced. That only changed the speed that it vibrated at and made it worse. Doesnt really matter for me now as I have cut all the IFS crap out from under the truck and new tires/wheels are coming as well.
  8. Jul 21, 2012 at 3:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Nice !! & emphasize the IFS CRAP!!
    is right...:D
