Odd vibrations - 2017 Tacoma TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwolgy88, Jun 14, 2017.
  1. Jun 23, 2017 at 12:00 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I would try a different dealership. Its pretty obvious from your videos there is an abnormal shake in the steering wheel. Could be anything from an alignment issue, wheel balancing, or drive train balancing. If your claiming that it shakes like that on all roads and highways, get a 2nd opinion at a different dealership.
    harrycary likes this.
  2. Jun 23, 2017 at 12:05 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I noticed part of your video is at ~2100-2200 RPM. Have you seen the buzzing vibration thread?
    https://www.tacomaworld.com/threads/buzzy-vibration-at-certain-rpms-read-before-buying.397620/
    Part of it may be due to that. At that RPM I have quite a strong buzzing, high frequency vibration in the steering wheel, floor, gas pedal etc.
    You could have other issues as well but at least that I think it just a shitty design and failure to damp out engine/exhaust vibration.
  3. Aug 2, 2017 at 12:44 PM
    cwolgy88
    cwolgy88 [OP] Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    For those following, I swapped my stock wheels back onto the truck and my steering wheel shimmy at highway speeds greatly improved but is still present at points in time.
    I took the truck to my dealer today for the 5k service and to look at this issue again, as it's still there on my stock wheels, and they 4 different people couldn't feel or see any issue in the steering wheel.
    Other than getting my aftermarket wheels balanced for a 3rd time, does anyone have any other suggestions? Are all terrain tires just more prone to road noise/feedback?
  4. Aug 2, 2017 at 12:47 PM
    cwolgy88
    Cody
    None as of yet
    Just seeing this reply but yes, the shimmy in the steering wheel has happened on several different roads and speeds but it's not constant, as in it has happened on the same road where it hasn't done it. It's more noticeable on my aftermarket wheels with A/T tires (videos taken on these wheels) compared to the OEM wheels but it is still present.
  5. Aug 14, 2017 at 6:48 AM
    cwolgy88
    Cody
    None as of yet
  6. Aug 14, 2017 at 7:43 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Is the shop balancing your aftermarket tires and wheels with a Hunter Road Force balancing machine?
    If not then find a shop that has one and try it
  7. Aug 14, 2017 at 7:51 AM
    coma toy
    coma toy Off Road Taco
    I 2nd that. Especially since it's still under warranty. You'll kick yourself after the warranty for not doing it sooner.
  8. Aug 14, 2017 at 7:55 AM
    cwolgy88
    Cody
    None as of yet
    It's Belle Tire who did the balanced initially and after I took them back and they said they were in fact Road Force balanced. I do plan to have the Dealership give it a go balancing them too.
    I've thought about this, the next nearest one is almost an hour away but it's worth it if they can actually help me. Thankfully I have a Lifetime Powertrain warranty, and also the Toyota Extended warranty that covers everything else the other one doesn't.
  9. Aug 14, 2017 at 9:50 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Ask the Dealer to let you drive another new truck to see if it vibrates the same way.
  10. Aug 14, 2017 at 10:01 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Loose engine or transmission mounts.
  11. Aug 14, 2017 at 10:30 AM
    cwolgy88
    Cody
    None as of yet
    Not a bad idea, I'm going to have the Dealer re-balance my aftermarket wheels (3rd balance) to rule that out (again) and could test drive one during this.
    shakerhood[QUOTED] likes this.
  12. Aug 14, 2017 at 11:53 AM
    shakerhood
    Southern Ohio
    Since you haven't had a truck before it would be best to rule it out by driving another one, that said, I've owned 4 Tacoma's and none have vibrated.
    CH Luke and cwolgy88[QUOTED][OP] like this.
  13. Aug 14, 2017 at 2:44 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    My stock tires shook a bit too. Then I bought T4R Pro rims with KO2 tires and the steering shook like crazy. Had to have them rebalanced 3 times, then they were smooth as glass. All shaking stopped until I ran over a piece of metal on my rear tire. Had the tire replaced the eve before I took off for a trip up north. That was the worse ride I've ever taken in my life. The truck bounced and seats shook for the whole 800 mile round trip. Then I took it back to Americas tire when I got back home to have it rebalanced and it's back to smooth as glass for me. So, I think it may be a balance issue... I'd take it back to have it rebalanced.
  14. Aug 14, 2017 at 7:10 PM
    cwolgy88
    Cody
    None as of yet
    This gives me hope! Really hoping it is just a tire balance issue but after having them rebalanced twice I lost hope. As I said I'm going to have the Dealer do it this time around instead of Belle Tire.
  15. Aug 14, 2017 at 7:42 PM
    #35
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    How did you get a lifetime power train Waranty?
  16. Aug 15, 2017 at 10:54 AM
    #36
    joemc
    joemc Well-Known Member
    Joe
    2017 TRD Sport Access Cab
    You go to a dealer that offers it. Normally requires you to do all service at that dealer.
    harrycary[QUOTED] and shakerhood like this.
  17. Aug 15, 2017 at 1:03 PM
    #37
    cwolgy88
    Cody
    None as of yet
    It's just something my specific dealer offered, included with the purchase of a new vehicle. They're the only one in Michigan to do it.
    harrycary[QUOTED] likes this.
  18. Aug 30, 2017 at 1:42 PM
    #38
    NordGord
    NordGord New Member
    Calgary Canada
    2017 Silver Tacoma TRD Sport Upgrade Auto
    I also had a vibration issue on my TRD sport 4x4 which was very close to the video at the beginning of this post. After getting my tires balanced the second time with a Road Force Balancing Machine, the Vibrations were virtually eliminated. I'm including a You Tube video that explains what the significates are and possibly why the vibration issue isn't a problem for the TRD Off Road which have larger profile tires.
    https://www.youtube.com/watch?v=nbL9vMRbMCA
    https://www.youtube.com/watch?v=DQxVAssnbp8
    cwolgy88[OP] likes this.
  19. Aug 30, 2017 at 4:26 PM
    #39
    cwolgy88
    Cody
    None as of yet
    Thanks for your input and the videos! I've been meaning to get into the Dealer to have my wheels re-balanced for the 3rd time. Both of the previous times were on a Road Force machine (or so they said) but in hoping the Dealers is better or more accurate.
  20. Aug 30, 2017 at 5:13 PM
    #40
    smcfarla
    smcfarla Well-Known Member
    CT
    2017 TRD sport, red
    The steering wheel shake is definitely not normal. I also have the trd sport and have never had the shakes you do. For a companion point I owned a 2013 RAV4 before the Tacoma. Obviously the Rav4 was "sportier" (I know...hard to call a soccer mom car sporty, I hate myself for typing it), but I personally don't find the ride quality to be drastically different. Cars always drift over the small bumps better and trucks handle the big ones better. Kinda averages out in my opinion. The only thing I notice is the 2k rpm noise/vibration mentioned in previous posts, which I suppose is normal for this truck, and some wind noise from the side view mirrors.
    Overall still love my access cab sport.
