Odd vibrations - 2017 Tacoma TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwolgy88, Jun 14, 2017.
  1. Aug 30, 2017 at 5:32 PM
    #41
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    Have them road forced balanced!
  2. Aug 30, 2017 at 6:44 PM
    #42
    cwolgy88
    cwolgy88 [OP] Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    I have, twice now, with Belle Tire. Have an appointment at the Dealer tomorrow to have them balanced on their machine which I'm hoping is better.
  3. Jan 15, 2018 at 11:17 PM
    #43
    Bdon
    Bdon New Member
    I have a 2017 4runner with what I believe to be a similar issue. I've looked at other forum and will post what they said, also solutions they found. I had a bearing replaced in my front diff. I bought my 4runner in GA moved to TN. Took a trip from TN to IL Dec 17 and when I arrived I had a rhythmic vibration/rumbling noise. 40mph is where you could hear it and the sound increased when coasting from that speed. Toyota has a "recall" I'm not sure they are officially calling it that, on the bearing in the front diff. I had mine changed but that did not help. Long story short with telling the dealer that's not a "normal Toyota noise" they amazingly heard the glorious sound and decided to replace the whole front diff. Test drove it after that was replaced (at 40mph) alot better but a very slight vibration, however I figured maybe a tire balance would fixed that so I wasn't worried. Then I got on the highway and at 70mph it has a very fast vibrating sounds. You can feel it in the floor board and a little in the steering but my steering wasn't shaking out of my hands. Called the dealer back so now they know I will be back. Good luck
    Here's the link for more info. The dealer is being a douch, try another dealer and ask them to ride with you. Good luck
  4. Jan 22, 2018 at 4:19 PM
    #44
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Vibrations from the floorboards = off balance driveshaft?
  5. Jan 23, 2018 at 8:25 AM
    #45
    oldharleyguy
    oldharleyguy Member
    Ontario
    2017 Black Sport
    265/70/17 Coopers, 17" Fuel Vapor, 2 inch level, Catzskin grey leather, Extang solid fold
    Doubt it would be driveshaft. Have you raised/lifted/put higher tires on it?
  6. Feb 23, 2018 at 7:32 AM
    #46
    Jminch
    Jminch New Member
    Exact same issues with my 2017 SR5 along with shuddering and a washboard vibration while braking. Washboard sensation also occurs while coasting at 25 mph. Currently in lemon law with Toyota. Wheels and tires have been replaced and rear brakes have been replaced 4 times by dealership and by Toyota's field service tech. The problem is progressing.
  7. Feb 23, 2018 at 1:31 PM
    #47
    oldharleyguy
    oldharleyguy Member
    Ontario
    2017 Black Sport
    I believe the 55/60 mph vibration is a separate entity to the braking vibration. I had the ecgs bushing put in and the speed vibration was eliminated. The braking washboard pulsation is still happening.
  8. May 22, 2018 at 7:10 PM
    #48
    LtPeteMitchell
    LtPeteMitchell Well-Known Member
    2018 TRD OR
    Any update here? I’m having the same issues. Random vibrations. Sometimes smooth, comes and goes.
  9. May 22, 2018 at 8:11 PM
    #49
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I would have an alignment done see if symptoms improve most overlooked this best to rule it out....since the truck is new I think it’s a bad steering rack...they are a real bitch to replace in these trucks!
  10. May 22, 2018 at 8:54 PM
    #50
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I had a similar highway vibration on a previous FWD car that could not be resolved by the dealer. It turned out to be a bad inner CV joint. Since then, I have seen them fail on other cars. Have them check the inboard CV joints for excessive movement.
  11. May 23, 2018 at 7:17 AM
    #51
    oldharleyguy
    oldharleyguy Member
    Ontario
    2017 Black Sport
    Search out East Coast Gear Supply on this site for their bushing to address this problem.
  12. May 6, 2019 at 11:33 AM
    #52
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    Did the dealer RF balance end up doing the trick?
  13. May 6, 2019 at 4:29 PM
    #53
    BamaTaco356
    BamaTaco356 Member
    2018 White Tacoma TRD Sport
    2018 TRD sport 4x4 and mine has the exact same issue. Ive taken it to 3 dealers multiple times, had a high dollar offroad shop look at it twice and the truck still shakes exactly like yours. mine shakes bad enough to shake the passenger seat back and forth as you drive. Its just the truck I guess. I am buying King coilers to hopefully help with the road feel since the sports come with a firmer suspension from the factory.
  14. May 31, 2019 at 6:45 PM
    #54
    Grey_TRD Tacoma
    Grey_TRD Tacoma Well-Known Member
    Jamie
    Tampa Florida
    2016 TRD Sport 4x4
    32x10.50 falken wildpeaks OME 887 coils Bilstein 5100s Dirt King UCAs OME Lean plate ICON AAL RCI front skid RCI rock sliders
    The ecgs bearing eliminated your 55/60 vibration? I’m wondering is that is my issue.
  15. May 31, 2019 at 7:16 PM
    #55
    SgtPuddin
    SgtPuddin Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    It’s definitely front wheel balance issue.
  16. May 31, 2019 at 9:06 PM
    #56
    surfyota
    surfyota Well-Known Member
    mike
    Tampa, Florida
    17 mgm dcsb Trd sport 4x4
    Lifted, kmc 17x9, Cooper 33s, katzskin leather, topper, front bumper light bar.
    my seat shakes, feel vibes, this is my 2nd 3rd gen, both did the same thing. im lifted with bigger tires and all that but my 1st one was stock and still the same. my buddy has a 18 trd sport 4x4 bone stock and his seat shakes and has vibes. owned a lifted ram 1500 on 20in wheels and 35s felt like a cloud never had a single vibe. tacomas ride like crap but dam do they look cool:D
  17. Jun 1, 2019 at 4:49 AM
    #57
    SgtPuddin
    Mississippi
    My front seat shakes a bit as well but definitely don’t have a dancing coke in my center console. That’s crazy.
  18. Jun 1, 2019 at 9:37 AM
    #58
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    I had a shimmy between 55-60 with factory steel wheels and some cheap tires that came with it at purchase (bought used). Had it balanced 3 times and never fixed. Just bought factory alloy wheels with the factory Firestone’s and the vibration is nearly completely fixed. Its most like a tire/balance issue.
  19. Oct 1, 2020 at 9:10 PM
    #59
    Kwisak
    Kwisak Well-Known Member
    Jon
    Arizona
    2024 Tundra Limited off-road 2018 Inferno Tacoma Off Road MT
    Pro grill Joying radio with wireless car play Hood decal Bed decal Pro skid Pro wheels 285/70/17 Sliders Blackout emblems Pro exhaust Pro intake Painted engine cover Ditch lights Tint Tacoma letters glove box Off-road wether tech inserts Lock box console Blackvue Orange trim Orange inserts Katzskin Weather tech Bed mat Hilift Tire locks Extra switch Rotopax Fox 2.5 fronts with 700lbs Kings Fox 2.0 rears with resi Icon rxt springs Icon Delta UCAs Meso side markers Meso gashole On order —— Avid bed rack SSO bumper Morimoto headlights and fogs Meso map lights and done light
    No, did this last week and honestly feels the same
  20. Dec 23, 2020 at 1:35 PM
    #60
    GlenPxC
    GlenPxC Active Member
    Saint Louis, MO
    OP wondering if you ever got your vibration issue resolved? I’ve been through 3 sets of wheels and tires and still have vibrations at 55mph+.
