Odd water leak on drivers side, any help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xufer, Aug 4, 2018.
  1. Aug 4, 2018 at 3:24 PM
    xufer
    xufer [OP] Tacos?
    2018 TRD OR AT DC Cement
    I have a 2018 DCSB, after the past two rain storms I have noticed that the seat belt on the drivers side was completely soaked. Today I also noticed a puddle on the rear floor mat behind the driver seat. Has any one else noticed a leak like this or does anyone know of any place this could be coming from ?
    Thanks TW.
  2. Aug 4, 2018 at 3:27 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Do you have a sunroof? I mean, if not, the highest point that could touch a seat belt is a door seal.
  3. Aug 4, 2018 at 3:32 PM
    xufer
    xufer [OP] Tacos?
    I do have a sunroof, and the door seals seem to be good and I do not see any water on the door jams but I also do not see any water on the roof liner. I also had the dealership add in the oem roof rack which could also be a leak point but i do not see anything...
  4. Aug 4, 2018 at 4:17 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Its likely the roof rack. If the dealer installed, it should all be covered under warranty. Bring her in
    2016Tacoman and over60 like this.
  5. Aug 4, 2018 at 5:56 PM
    here4cake
    here4cake Well-Known Member
    Totally the roof rack. Bet you they didn't seal the threads when they installed the rack, and simply bolted it into place.
  6. Aug 4, 2018 at 6:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Roof Rack leak
    tcjacado likes this.
  7. Aug 4, 2018 at 6:11 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Roof rack
    Had a similar leak on on old blazer
    Would drip out the front of headliner
    The dealer keep sealing wind shield
    Kept telling him it was roof rack
    Took them 3 tries till they listened
    shakerhood likes this.
  8. Aug 4, 2018 at 8:53 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    They screwed up the roof rack install.
  9. Aug 4, 2018 at 10:35 PM
    xufer
    xufer [OP] Tacos?
    They messed up the roof rack install twice I had them re do it. I should have done it my self but I kept bringing it back for those morons to fix. Finally the thing was bolted correctly and the weather seals were flush. If it’s leaking now I’m going to really begin to wonder if they should continue to get my business.
  10. Aug 4, 2018 at 10:39 PM
    tcjacado
    tcjacado Well-Known Member
    Well it's one of those 2 things mentioned above...... roof rack or sun roof.;)
  11. Aug 5, 2018 at 4:25 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Without being a rocket scientist I would bet it's your rack. Have someone run a hose and sit in the cab and check it out.
    Unless you want to pay someone else cause there not going to do it for free then bring it back and make um do it right! You know what they say about the third time.:D
  12. Aug 12, 2018 at 9:33 PM
    xufer
    xufer [OP] Tacos?
    had them fix it, take it all apart and dry it out and put it back together. then when I got it home I made sure they actually cleaned and dried it properly... I hate dealerships... one day I'll find a good one.
    Toms 17 likes this.
