ODO on my dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougmays, Jan 9, 2008.
  1. Jan 9, 2008 at 11:54 AM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    i've had my tacoma for about 7 months now and it just dawned on me that by my odometer it reads ODO. i'm assuming this is "overdrive on". Is this correct or is it overdrive off? Do you guys ride around with the odo light on or off? should i turned ODO off for trailering?
  2. Jan 9, 2008 at 12:21 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I think the ODO means odometer. If you push the button, it'll change to 'trip1', then a second time to 'trip2', IIRC. I'm pleased with the dual trip odometers. Let's me monitor a tank of gas on trip1, plus the distance to someplace on trip2
  3. Jan 9, 2008 at 12:24 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    sawdust, you are too easy to please. I think that a Kia might even have more info on their dash than our Tacomas. I get into some people's chevy's and they have tire pressures, mpg, %oil left, etc...
  4. Jan 9, 2008 at 12:32 PM
    sawdust
    Frisco, TX
    Don't get me wrong, I'd like to have instantaneous mpg, oil pressure, voltage, etc too. I was limiting my response to the topic at hand, the odometer. There's a scangauge on my wish list for the extras. My Dad bought a new Sierra a couple of months before I got my Taco. He's got all that. My only point to brag to him is that I've got a Homelink mirror with the garage door opener and he doesn't. Mine was one of those "port" options we discussed a while back. Came with the truck as far as I'm concerned.
  5. Jan 9, 2008 at 1:49 PM
    dougmays
    Doug
    Gainesville, FL
    ohhh ok i'm just retarded...i know my last car had odo on it and that meant overdrive on
    thanks for the clarification
  6. Jan 9, 2008 at 3:24 PM
    sawdust
    Frisco, TX
    I thought that was just something so obvious it got overlooked. On the topic of your other point about overdrive while towing, that depends on whether you have the manual or automatic transmission. On the auto, I normally drive in D, but if towing, you're supposed to use 4.
  7. Jan 9, 2008 at 3:29 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    hmmmm.... Mine says "trip a" and "trip b"..... Numbers must be a texas option. :D
  8. Jan 9, 2008 at 5:41 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Don't sweat it, it's all good, you're not retarded, were all learning here. :thumbsup:
  9. Jan 10, 2008 at 6:12 AM
    dougmays
    Doug
    Gainesville, FL
    ok so what is the button down on the top left corner my my shifter (auto trans)? you have to remove the cover piece to get to it
  10. Jan 10, 2008 at 6:36 AM
    argm31i
    argm31i Well-Known Member
    I believe you're talking about the cover for the button to disengage the "brake must be depressed to shift out of P" (sorry, don't have a clever title for it) feature. You pop that cover off and there's apparently a button under there that you can push down that allows you to shift out of "P" without having to depress the brake pedal.
  11. Jan 10, 2008 at 6:45 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Probably lets you shift out of park without the truck running. Most autos have something like that.
    Edit: Try it, but I think you still need to push the brake. That would be like yanking a manual out of gear without holding the brake. The truck could start rolling. Normally you can't shift out of park without the key in or engine running (forget which). I'm sure it's in the manual somewhere.
  12. Jan 10, 2008 at 6:50 AM
    99TRD
    99TRD Well-Known Member
    17 Tacoma TRD OR DC Auto V6
    Smoke headlights, improved LED tail lights...Pending: De-chrome badges and grille, new tires
    I noticed the same button down there too. My button cover is gone and I would like to get a new one if anyone knows where. I assumed it was an emergency release button for the shifter.
  13. Jan 10, 2008 at 6:51 AM
    99TRD
    See what happens when you take too long to write the post?
  14. Jan 10, 2008 at 4:05 PM
    MMurray
    MMurray Active Member
    Rural Madison County IA
    2017 Access Cab TRD Off Road
    None yet
    Just to let you know we are all learning. It took me two weeks to realize if I want the interior lights to come on when I unlock the door I need to hit the button twice.
    I thought it was kind of strange when I would unlock it and not get the interior lights...........
  15. Jan 10, 2008 at 4:41 PM
    concrete jedi
    Rochester N.Y
    It's fun to learn kids ! :eek:
  16. Jan 11, 2008 at 3:04 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Nope it means the alien guy on Star Trek Deep space nine. I was thinking about that the other day and my wife and I came to this conclusion. ;)
  17. Jan 12, 2008 at 3:52 PM
    ED R
    ED R Well-Known Member
    My '07 doesn't require the brake pedal pushed to swtart.
  18. Jan 12, 2008 at 4:30 PM
    piercedtiger
    Jon
    Southern Tier, NY
    ^ huh?
    It's not about needing the brake to start... It's about pushing the brake to shift out of park.
