odometer help 3rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95tacomeat, Dec 2, 2014.
  1. Dec 2, 2014 at 8:39 PM
    95tacomeat
    95tacomeat [OP] New Member
    Joel
    GA
    95 Taco 4x4
    3rz full k&n intake, magnaflow high flow cat, dynomax exhaust, 3 susp lift, 3 body lift, 4.88 gears, 35's, procomp 15 wheels, radio, hurst handle.
    Hey I recently traded for a 95 tacoma with a 3rz. Only problem so far is the odometer has stopped?!:confused: And the speedometer is shakey not bad but shakey. Figured the two may be of the same problem. Forgive me if this has already been gone over this is my first post i am brand new to the forum!:D thank is advance!
  2. Dec 3, 2014 at 10:45 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    check to see if everything is plugged in ok back there, maybe its a loose connection
  3. Dec 9, 2014 at 5:30 PM
    95tacomeat
    Joel
    GA
    95 Taco 4x4
    Everything checks out guess its time for a new odo
