Odometer trip report
Discussion in 'Trip Reports' started by BeerForMyHorses, Dec 18, 2021.
  1. Dec 18, 2021 at 10:28 PM
    BeerForMyHorses
    BeerForMyHorses [OP] Well-Known Member
    I bought my truck new in October and just recently took it on a 1200 mile road trip. I was interested to discover that my odometer is off by about 4.5%.
    Context: 2021 TRD OR DCSB 6MT with factory lift and 275/70r17 Falken Wildpeaks.
    I was curious if my odometer was off due to the larger tires. There were several stretches of road where I compared the odometer to the GPS. The truck consistently showed 95.5 miles for every 100 miles on the GPS.
    When I applied that conversion to gas mileage, I was pleased to find I was getting 1-2 mpg better than what the truck was calculating.
    Other than that, the truck handled great in the mountains. I drove through Idaho up into western Montana. I'm pretty happy with it.
    Road_Warrior likes this.
  2. Dec 19, 2021 at 6:23 AM
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Alexandria, VA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for Qi charger, Owl Dash Cam and Motorola GMRS; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Compustar remote start, USB charger for the rear seats, Husky Mats, Lexus Credit Card Transponder Fob, MAG Light mount, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune....help me I can't stop!!!
    yes larger tires will cause this…
  3. Dec 19, 2021 at 7:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Tire calculator
    This will show % delta between stock size and size you are running.
    However, speedos are notorious for registering a bit fast, so some correction may actually occur with taller tires.
    Thanks for doing actual research and math before posting. And particularly for not dropping in with some silly miles-per-tank question!
    EagleUSMCRet likes this.
  4. Dec 19, 2021 at 7:34 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Some great info here, thanks for posting.
    I’m running larger tires as well and didn’t know about this.
  5. Dec 19, 2021 at 8:45 AM
    BeerForMyHorses
    Right. I just thought it was interesting see usage numbers behind it. 4.5% seemed higher than I expected.
  6. Dec 19, 2021 at 10:13 AM
    EagleUSMCRet
    Alexandria, VA
    I had a similar, but lesser %, experience w/ larger tires on my 2006 Tundra. Also affects the speedo reading… with larger tires, you will be going a faster MPH than you are reading.
  7. Dec 19, 2021 at 10:27 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    As your tires wear down the diameter changes. By the time they are worn out they will be closer to stock size and your odometer and speedometer will be closer to being accurate. Normally tires at the end of their useful life will be about 1 size smaller than when new. You basically went up 2 sizes so they will still be a little bigger than stock when worn out.
  8. Dec 20, 2021 at 8:01 PM
    BeerForMyHorses
    I've noticed that. I downloaded a speedometer app on my phone. When I set my cruise to 30, I'm going 31. When I set 60, I'm actually going 62. Not a big difference but I keep it in mind if I'm speeding.
