Odometer trip reset switch - stopped working
Discussion in '1st Gen. Tacomas (1995-2004)' started by BackCountry, Nov 17, 2014.
  1. Nov 17, 2014 at 8:19 AM
    BackCountry
    BackCountry [OP] Well-Known Member
    2001 TRD
    Here's a strange one, unless I'm searching the wrong term, I can't seem to find any info about this 'glitch'.
    A couple of days ago my Odometer Trip Reset switch stopped working. Now it's just stuck on Trip B. I've tried long presses, short presses, and it won't budge.
    I need to get my main Odometer reading to renew my plates...
    Any thoughts?
    Thanks.
  2. Nov 17, 2014 at 9:04 AM
    BackCountry
    2001 TRD
    Disconnected the battery for a couple of minutes and was able to get back to my main odometer reading. Trip switch still doesn't work though. I use that a lot, so would like to fix it.
  3. Nov 17, 2014 at 11:38 AM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    Does it still feel like it has resistance when you push it in? Like a click towards the end?
    I had something similar on another car happen and after I opened the speedo housing it turned out the long "lever" that pushed the button behind the plastic was off the button itself... if that makes any sense.
    --Dan
  4. Nov 17, 2014 at 11:40 AM
    BackCountry
    2001 TRD
    Makes sense. The stick feels normal, still feels like it's pushing the button in.
  5. Nov 17, 2014 at 12:14 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    sounds like the electronics stopped working, as long as you have your odometer reading I would just live with it. the only solution I can think of is to replace the cluster or odometer module in it if that's even possible and then your odometer will be off unless you get lucky enough to find one with about the same miles.
  6. Nov 17, 2014 at 2:01 PM
    BackCountry
    2001 TRD
    Dang... I guess these little electrical gremlins were bound to start popping up given the trucks age.
