Odyssey or Optima?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crgrey42, Jan 27, 2017.
  1. Jan 27, 2017 at 7:26 AM
    Crgrey42
    Crgrey42 [OP] Well-Known Member
    Cory
    CNY
    Superwhite 13 TXPRO DCSB
    I need a new battery soon, and I am torn between these two. I have LED's all over and will be mounting my winch soon. What are you all running and why?
  2. Jan 27, 2017 at 9:12 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Optima ran into some serious QC issues a few years back. Don't know if or when it was corrected. Odyssey is an amazing battery. That's what they run in many high end applications; ambulances, etc.
  3. Jan 27, 2017 at 9:37 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use a Napa Ledgend battery and it works fine. I power a sub, kc lights, and pods. Works fine and always has lots of power
  4. Jan 27, 2017 at 9:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I prefer Odyssey as I've been a witness to a few failed optima batteries. Cost for an Odyssey is decent too, 3years and mine is happily going strong still
  5. Jan 27, 2017 at 9:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Northstar. If you haven't heard of them, do some research.
    Optima yellow top, Odyssey and Northstar are all AGM types and will be better than a traditional 'wet' lead/acid battery. But you will pay more.
    Odyssey and Notrthstar are at the top of the food chain in this category. The next tier down would be optimas and the price points will reflect this.
    Personally, I am very happy with my Northstars. I am running a pair of 24Fs. They are on their 2nd winter.
    Crgrey42[OP] and Speedytech7 like this.
  6. Jan 27, 2017 at 8:39 PM
    Crgrey42
    Cory
    CNY
    Just checked the northstar out. Looks like thats the direction i am going. And cheaper than i had imagined.
    Digiratus[QUOTED] likes this.
