OEM 2014 Tacoma Navigation Radio
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by FLTrucks, Oct 14, 2013.
  1. Jan 28, 2014 at 7:09 AM
    #241
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    That is correct. Prevent theft.
  2. Jan 28, 2014 at 12:27 PM
    #242
    peto48
    peto48 Well-Known Member
    Central NY
    2020 Tacoma DCSB TRD Off Road Cement 4x4
    Salex Center console organizer, glove box organizer, Husky Xact contour front and rear digital floor liners, OEM black running boards, TRD PRO Sema 4runner wheels black, Blackout badge kit, Bakflip MX4 hard folding tonneau.
    Also, depending on the year, full plug and play, no harnesses, kits or adapters as well as the OEM clean look. Mine was a straight swap and was done in 15 minutes, steering wheel controls and USB aux fully functional. That's what swayed me to OEM.
  3. Jan 28, 2014 at 1:40 PM
    #243
    FLTrucks
    FLTrucks [OP] Well-Known Member
    This right here is the exact reason.
    A decent aftermarket head unit will run you 300 plus. Then you have to get the matching steering wheel controls will run you 80 to 140 or more. Then you have to get the power and speaker wiring kit that comes with a faceplate that could you run you 20 plus. That right there is equivalent to my unit. Now you have to take the hour or more, depending on skills, for installation for said aftermarket unit. You will have to find areas to place your usb if it is not on the deck itself. There is more to the cost of an aftermarket head unit then I guess you would think.
  4. Jan 28, 2014 at 3:06 PM
    #244
    sudome
    sudome New Member
    Texas
    PreRunner
    I would be interested if you got more.
  5. Jan 28, 2014 at 4:41 PM
    #245
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Well, jumped the bandwagon. Can't wait to get mines.
  6. Jan 28, 2014 at 5:05 PM
    #246
    firemanjay
    firemanjay Active Member
    Bristow, VA
    2014 Tacoma Off Road
    Mine should arrive on Thursday!
    Looking forward to it.
  7. Jan 29, 2014 at 5:59 AM
    #247
    firemanjay
    Bristow, VA
    If you sent that with the HU it will be here tomorrow
    Will let you know
    Thanks
  8. Jan 29, 2014 at 7:34 AM
    #248
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    I finally got my XM antenna figured out. If anyone has any questions feel free to pm me
  9. Jan 29, 2014 at 6:58 PM
    #249
    superskaterxes
    superskaterxes Active Member
    Just installed this in my 2009. I bought the 28pin split harness and the Mic and everything works like factory (including steering wheel controls). This headunit is absolutely beautiful and if your even remotely on the fence i would get it. The Navi is incredibly accurate and gives you those bonus features like which lane to be in when exiting the highway.
  10. Jan 29, 2014 at 8:32 PM
    #250
    jptx65
    jptx65 Member
    Jeff
    The Woodlands, Texas
    2013 PreRunner SR5
    Bilstein 5100's Front and Rear Hellwig Rear Sway Bar ImMrYo Rear-View Mirror Lift Bracket Katzkin Leather Seats
    I just finished installing the 2014 Nav radio in my 2013. It took about 30 minutes. Everything works perfectly. Now I need to sell my 2013 touch screen unit. Thanks FLTrucks!
  11. Jan 29, 2014 at 11:18 PM
    #251
    gunhound
    gunhound Gunhound
    CO
    2013 DCLB Sport
    5/15 tint, NFab step bars, Viper SST, Weathertech floor liners, Toyo A/T IIs on 17x9 XD Menace wheels. Lift - SPC LR UCAs, Wheelers 3 pc AAL, OME N140s, N182 and 885 w/ TP spacers.
    +1
    Arrived this afternoon and installed it right away.
    Thanks again FL Trucks.
  12. Jan 30, 2014 at 12:34 AM
    #252
    larboleda
    larboleda Member
    Ventura County, CA
    10 PreRunner TRD Sport
    Thanks FLTrucks, and also for the install gear! I think all of us here absolutely appreciate the units to get us set up!!! :):D;)
  13. Jan 30, 2014 at 8:31 AM
    #253
    firemanjay
    Bristow, VA
    Received mine today.
    Install took about 30 min.
    Didn't need the GPS Ant. seems mine was already wired for it
    also didn't need the faceplate or brackets mounted right up to the existing faceplate and brackets as well as XM
    Will need to get a good VIN for the Entune apps to work.
    Thanks FL trucks
    Great Unit Extremely HAPPY
  14. Jan 30, 2014 at 1:28 PM
    #254
    Duck76
    Duck76 Active Member
    British Columbia, Canada
    13 Tacoma TRD Sport DCLB
    Got mine yesterday and installed last night. Super quick and easy to install. Goods were packaged very well and shipping was quick too.
    Thanks FLTrucks!
  15. Jan 30, 2014 at 3:02 PM
    #255
    InducedComa
    InducedComa Well-Known Member
    Paul
    Northern VA
    13 TRD Sport DCLB
    OME Nitrocharger shocks, 885x Springs with Toytec 3/4 inch spacer, LR UCA's, DAKAR Leaf Springs, Line-X'd Avid Offroad Step Bars, Pop-N-Lock Power Tailgate Lock, Truxedo TruXport Roll-Up Tonneau
    How long is the waiting list to get one of these?
  16. Jan 30, 2014 at 4:34 PM
    #256
    firemanjay
    Bristow, VA
    Would someone who has already installed this unit check theirs to see if the buttons are backlit
    Seems mine are not, don't know if it is supposed to be that way or if something is wrong with mine.
    Thanks in advance
  17. Jan 30, 2014 at 4:37 PM
    #257
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    maybe with the parking lights turned on?
  18. Jan 30, 2014 at 4:47 PM
    #258
    firemanjay
    Bristow, VA
    I have tried parking lights on.......was driving this evening so all my lights where on
    With lights off.........the screen auto dims with the lights on or off
    Tried moving the light dimmer knob up and down a couple of times
    Nothing........
  19. Jan 30, 2014 at 8:11 PM
    #259
    Phil5393
    Phil
    TRD Sport
    Do your climate control lights or any other dash lights work?
  20. Jan 31, 2014 at 3:15 AM
    #260
    firemanjay
    Bristow, VA
    Yes every things works as it's supposed to
