Oem 2015 double din radio swap in a 06 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ventenueve, Oct 6, 2021.
  1. Oct 6, 2021 at 6:18 AM
    Ventenueve
    Ventenueve [OP] Active Member
    David
    Ral, NC
    2006 Access cab 2.7 5spd 4x4 blue
    Camper build in progress…new build mods to come 2006 V8 4Runner SR5 Previous trucks 97 3.4 5spd 4x4 ext cab 98 2.4 SR5 ext cab 98 limited 4 Runner 98 SR5 4 Runner
    Has anyone upgraded a non aux radio(06 ) with a newer double din from a 2012 -15 ? I just want to have the aux feature/Bluetooth more than the steering wheel controls which mine does not have but have seen the steering wheel for sale, I’ve seen the aux input for sale and need
    To source the cable
    Would also like to add The tailgate camera in the near future
  2. Oct 6, 2021 at 6:37 AM
    Ventenueve
    David
    Ral, NC
    I have a found a factory head unit/speakers for $100 , seller says it has the camera display on the unit, want an easy plug and play system that plays phone tunes sounded like a cheap
    Option
  3. Oct 6, 2021 at 6:55 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    I don’t have an answer for your specific question, but thought I’d share my solution for the audio part. I bought a Bluetooth to AUX adapter on Amazon for $30 (BESIGN BK01) and I’m pretty happy with it. It wouldn’t help you with the backup camera, but those are available aftermarket as well. The audio quality is quite good, unlike with any of the Bluetooth to FM adapters I’ve ever tried.
    (edit) Upon rereading your post, seems likely that your truck’s radio may not even have an AUX input. If so, this clearly isn’t going to be a solution.
  4. Oct 6, 2021 at 7:55 AM
    Ventenueve
    David
    Ral, NC
    Correct no aux input, base model 06, had the vitals 5 spd,4x4, figured I could figure out the rest of my needs, and this head unit seemed like a plug and play.Yes my current remedy is the FM adapter isn’t terrible but leaves a lot to be desired….
  5. Oct 7, 2021 at 12:15 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I don’t think the radios are direct replacement. Believe some of the plugs changed around 2012 timeframe.
    I would look at a cheap aftermarket radio and then get the needed wiring harness. Match colors of harness to radio and then it is pretty much plug and play.
    Ventenueve[OP] and Jeffch like this.
  6. Oct 8, 2021 at 2:51 AM
    Ventenueve
    David
    Ral, NC
    I will confirm plug(s) prior to purchasing and update, sounds about right though, i did find an 09 with an aux plug for $50 but no screen for camera… aftermarket search it is
  7. Oct 8, 2021 at 3:24 AM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    I got a boss audio and it lasted 6 months. Maybe I had a bad unit but beware of cheap receivers.
  8. Oct 8, 2021 at 5:07 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    My stock 2013 stereo would not work over bluetooth. I ended up putting in one of the Joying/Dasaita chinese android head units.
    Get something with carplay/android auto, well worth it.
    Ventenueve[OP] likes this.
  9. Oct 8, 2021 at 5:11 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    A lot of people have problems with their factory units. I’d just got with a aftermarket double din if it was me. Crutch field has always been good to me and comes with the wiring harness to hook it up in your truck with minimal splicing.
  10. Nov 28, 2021 at 8:53 PM
    Ventenueve
    David
    Ral, NC
    Update so I pieced together a 2015 oem head unit with touchscreen and blue tooth and mic work usb traffic and weather, bought an aftermarket camera but can not ge the signal to cut the display on the screen have verified camera works and signal to the head unit via a tv where I plugged the camera into while in reverse, probably start a new thread to layout all part numbers used and such if anyone has any experience with aftermarket camera with factory head unit plz chime in thx
