OEM 2022 TACOMA TRD PRO FOX WESTCOTT DESIGN FRONT SHOCK SET
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by ill ay, Jan 23, 2025.
  1. Jan 23, 2025 at 8:45 AM
    ill ay
    ill ay [OP] I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    I have a set of OEM 2022 Toyota Tacoma TRD PRO front shocks with the Westcott Design lift for sale. They have under 8,500 miles on them and are in great shape. There are some normal signs of wear but most of the blemishes came from shop uninstalling and handling them.
    This would be an amazing upgrade for your 3rd Gen Tacoma as it will provide a 1.5" lift from stock height. The Westcott Design will provide a 1.5" lift. Visit Wescott Designs to read more about their amazing lift, it's NOT a spacer lift as it keeps the stock TRD Pro factory geometry and doesn't sacrifice the ride as intended.
    If you don't want a full 1.5" Lift. You can negate to use the additional top hat and that will take off .75" from the 1.5" The already installed bottom collar will only provide a .75"- 1" max lift. The top additional part provides the remaining portion of the lift and is optional.
    Price is $950 Local Pick-up in Studio City, CA. Right off Woodman and the 101 Freeway.
    The Westcott Design Lift Kit is $350 alone and doesn't include the labor to install it.
    https://westcottdesigns.net/product/2020-2022-tacoma-fox-trd-pro-lift-kit-front-only/
    rip ej1 likes this.
  2. Jan 26, 2025 at 11:13 AM
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    What did you upgrade to?
