OEM 7-pin wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 8th sin, Jul 2, 2009.
  1. Jul 2, 2009 at 6:07 PM
    8th sin
    8th sin [OP] Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    I have recently purchased an OEM hitch receiver and plug. I am looking to wire up the 7-pin plug as OEM as possible. I know there is a separate harness for the trailer plug, that I assume runs up to the engine bay. However I have seen things about certain trucks not having a 23P conenctor to plug into. Does anyone know anything about this connector, or where it is located? If I have to wire things up myself, I can but I'd rather just buy the harness if at all possible.
    Also, I'd assume I don't have the pigtail in the cabin for the brake controller as well correct?
  2. Jul 2, 2009 at 7:10 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    check at the bumper for the connector. my 7 pin has less than 2' of wires and goes into a connector at the rear drivers side just in front of the bumper at the bottom of the bed. i hope this is what ur talking about
  3. Jul 2, 2009 at 7:25 PM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    I checked there, there is loom but no open connector. I need the harness that goes from the pigtail up to the front of the truck.
    after a little more research, i sounds like there is a different harness that will give you a 4 pin and is readily available from a dealer. At $150 though it would be much easier to go with an aftermarket harness. I can run 12v to the back myself and wire up the brake controller later if I ever need to.
