OEM air intake? Hood insulation solution
Discussion in '1st Gen. Tacomas (1995-2004)' started by JSH3.4, Apr 2, 2020.
  1. Apr 7, 2020 at 2:13 PM
    1997tacomav6
    Denver
    I like that,mm I wonder how many cans would be needed
  2. Apr 7, 2020 at 2:19 PM
    Spuds
    Spuds Well-Known Member
    Dave
    2020 Tacoma SR5 4x4
    All LED lighting, K&N filter w/TRD air accelerator, black and tangerine Katzkin leather seats, JL audio Components, rubber floor liners, de-badged, (next mod: orange powered coated winter rims & JL stealthbox)
    Can I buy a hood liner from the dealership? Like do they make them for the 2020, they just don’t come with the trucks anymore?
    GQ7227 likes this.
  3. Apr 7, 2020 at 2:54 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    From the looks of the engine bay, this doesn't look like a show truck. So I wouldn't worry too much about the paint under the hood... :D
    JSH3.4[QUOTED][OP] likes this.
  4. Apr 7, 2020 at 3:35 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    In my case the outer fabric layer was peeled off because it had already separated in several spots. This left a surface of essentially fiberglass mat, very porous. Spraying it on and smoothing the imperfections took a few minutes to develop the knack. About the same as a fiberglass lay up job but trying to lay the goop on the surface as opposed to working it in and saturating the mat. IIRC it was two cans. Given the cost it shouldn't be a problem to start with one and get another if needed.
    NAPA had the 3M as well as Auto zone, back then.
    1997tacomav6[QUOTED] likes this.
  5. Apr 7, 2020 at 6:31 PM
    JSH3.4
    JSH3.4 [OP] Active Member
    Joe
    southern OH
    '97 3.4 4x4 Auto
    Haha, Yeah you got that right.
    jbrandt[QUOTED] likes this.
  6. Apr 7, 2020 at 7:09 PM
    paetersen
    paetersen Well-Known Member
    Umm. Hood Insulation is to protect the exterior paint fron excessive engine heat.
    GQ7227, cruiserguy and 1997tacomav6 like this.
  7. Apr 8, 2020 at 4:23 PM
    JSH3.4
    Joe
    southern OH
    '97 3.4 4x4 Auto
    That was my main concern, but obviously others have none and have no problems
    GQ7227 likes this.
  8. Apr 9, 2020 at 7:23 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wulf likes this.
  9. Apr 9, 2020 at 7:27 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Thanks for sharing this about Binford.
    1997tacomav6 and cruiserguy like this.
  10. Apr 9, 2020 at 7:52 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i do find it odd
    the only 1st gen pics with bad hood paint i've seen to be ones in the southern heat AZ TX CA, FL etc.
    and perhaps the peeling paint issues of 01-04 models that i don't know much about
  11. Apr 9, 2020 at 8:13 AM
    cruiserguy
    Elijah
    SEKS
    Wulf and CS_AR[QUOTED] like this.
  12. Jun 11, 2020 at 6:58 AM
    1997tacomav6
    Denver
    I’m going to try this route before mine goes south.
    It looks like it comes in a spray can and possibly a brush setup.
    Did you use a spray can or just the brush route or spray can and then brush?
